I have several profile for terminal. I can open all profiles on boot but they open in different windows with this cmd in startup applications:
gnome-terminal --window-with-profile=ablack && gnome-terminal --window-with-profile=agreeen && gnome-terminal --window-with-profile=aubergine && gnome-terminal --window-with-profile=beige && gnome-terminal --window-with-profile=cyan && gnome-terminal --window-with-profile=grey && gnome-terminal --window-with-profile=orange && gnome-terminal --window-with-profile=white && gnome-terminal --window-with-profile=yellow && gnome-terminal --window-with-profile=ablack
I tried to open one window with several tabs with this cmd without success:
gnome-terminal --window-with-profile=ablack && gnome-terminal --tab-with-profile=agreeen && gnome-terminal --tab-with-profile=aubergine && gnome-terminal --tab-with-profile=beige && gnome-terminal --tab-with-profile=cyan && gnome-terminal --tab-with-profile=grey && gnome-terminal --tab-with-profile=orange && gnome-terminal --tab-with-profile=white && gnome-terminal --tab-with-profile=yellow && gnome-terminal --tab-with-profile=ablack
How to make it work?
pa4080
  • 30,621
mamesaye
  • 153
To open a gnome-terminal window with few tabs we should use the option --tab. See gnome-terminal --help-all. Also in man gnome-terminal we can find this explanation:
--window-with-profile=PROFILENAME
     Open a new window containing a tab with the given profile.
     More than one of these options can be provided.
--tab-with-profile=PROFILENAME
     Open a tab in the window with the given profile.
     More than one of these options can be provided, to open several tabs.
So, to open gnome-terminal window with few tabs, we should use command as this one:
gnome-terminal --tab-with-profile=ProfileA --tab-with-profile=ProfileB --tab-with-profile=ProfileC
Compose your own command and test it into a terminal. If it works satisfactorily add it as an entry in Startup Applications:
There are few possible approaches how to open few gnome-terminal windows with few tabs in each. I would suggest to use a command as follow:
gnome-terminal --tab-with-profile=ProfileA --tab-with-profile=ProfileB && gnome-terminal --tab-with-profile=ProfileC --tab-with-profile=ProfileD
Another idea is to create separate Startup Applications entry for each gnome-terminal window.
pa4080
  • 30,621
