I have a "media stuff" computer connected to a TV that I use to play films, music and for gaming.
Lately I wanted to use either or both my Wii and PS3 joysticks via the bluetooth provided by the motherboard. At first my PC seemed to be able to detect the PS3 joysticks but not pair them. I was even able to pair a PS3 joystick and see the various actions I triggered, but the device would become unpaired when I closed the program.
I tried various ideas from how-tos here and there. The system finally ended up with the Bluetooth not able to work properly...
Now when I start a new session the Bluetooth icon near the hour is not showing. I can start the Bluetooth app but no devices are detected. I may have messed with drivers while following a modprobe instruction in the howtos.
sudo lspci | grep -i blue is not showing anything. Neither is lsusb
The motherboard is a GIGABYTE GA-Z87N-WIFI and bluetooth once worked.
I use Ubuntu 16.04.
How can I solve this?
A bit of output here:
louis@cinema-wifi:~$ sudo dmesg | grep Blue
[ 16.088420] Bluetooth: Core ver 2.21
[ 16.088438] Bluetooth: HCI device and connection manager initialized
[ 16.088441] Bluetooth: HCI socket layer initialized
[ 16.088444] Bluetooth: L2CAP socket layer initialized
[ 16.088448] Bluetooth: SCO socket layer initialized
[ 18.231336] Bluetooth: hci0 command 0x0c03 tx timeout
[ 26.227321] Bluetooth: hci0 sending initial HCI reset command failed (-110)
[ 28.231323] Bluetooth: hci0 command 0x0c03 tx timeout
[ 36.227354] Bluetooth: hci0 sending initial HCI reset command failed (-110)
[ 36.648754] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 36.648756] Bluetooth: BNEP filters: protocol multicast
[ 36.648760] Bluetooth: BNEP socket layer initialized
[ 8741.765627] Bluetooth: hci0 command 0x0c03 tx timeout
[ 8749.761485] Bluetooth: hci0 sending initial HCI reset command failed (-110)
[ 8811.536379] Bluetooth: hci0 command 0x0c03 tx timeout
[ 8819.532238] Bluetooth: hci0 sending initial HCI reset command failed (-110)
[ 8821.536199] Bluetooth: hci0 command 0x0c03 tx timeout
[ 8829.532066] Bluetooth: hci0 sending initial HCI reset command failed (-110)
louis@cinema-wifi:~$ sudo lspci -knn | grep Net -A3; sudo lsusb
03:00.0 Network controller [0280]: Intel Corporation Wireless 7260 [8086:08b1] (rev 73)
Subsystem: Intel Corporation Dual Band Wireless-AC 7260 [8086:4070]
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
Bus 002 Device 002: ID 8087:8000 Intel Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:8008 Intel Corp.
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 004: ID 041e:323d Creative Technology, Ltd
Bus 003 Device 003: ID 045e:0040 Microsoft Corp. Wheel Mouse Optical
Bus 003 Device 002: ID 04f2:0116 Chicony Electronics Co., Ltd KU-2971/KU-0325 Keyboard
Bus 003 Device 005: ID 8087:07dc Intel Corp.
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
