I am seeing these errors while trying to install Inkscapeor install any software for that matter.
When I try to use sudo apt-get install language-pack-en-base it shows the same error .
I also tried sudo dpkg-reconfigure locales and then tried to installInkscape - but it is not working.
abhilash@abhilash-Inspiron-3542:~$ sudo apt-get install inkscape
[sudo] password for abhilash:
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
gawk libgsl2 libgtkmm-2.4-1v5 libgtkspell0 libimage-magick-perl
libimage-magick-q16-perl libmagick++-6.q16-5v5 libwmf-bin python-numpy
transfig
Suggested packages:
gawk-doc pstoedit dia | dia-gnome libsvg-perl libxml-xql-perl
python-uniconvertor ruby gsl-ref-psdoc | gsl-doc-pdf | gsl-doc-info
| gsl-ref-html imagemagick-doc gfortran python-dev python-nose
python-numpy-dbg python-numpy-doc xfig
The following NEW packages will be installed:
gawk inkscape libgsl2 libgtkmm-2.4-1v5 libgtkspell0 libimage-magick-perl
transfig
0 upgraded, 11 newly installed, 0 to remove and 158 not upgraded.
8 not fully installed or removed.
Need to get 0 B/16.9 MB of archives.
After this operation, 107 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up util-linux (2.27.1-6ubuntu3.3) ...
insserv: warning: script 'K01runlcactivator' missing LSB tags and overrides
insserv: warning: script 'runlcactivator' missing LSB tags and overrides
insserv: There is a loop between service plymouth and procps if started
insserv: loop involving service procps at depth 2
insserv: loop involving service udev at depth 1
insserv: Starting runlcactivator depends on plymouth and therefore on system facility `$all' which can not be true!
insserv: loop involving service networking at depth 4
insserv: There is a loop between service plymouth and urandom if started
insserv: loop involving service urandom at depth 4
insserv: loop involving service mountdevsubfs at depth 2
insserv: There is a loop at service runlcactivator if started
insserv: There is a loop between service runlcactivator and dns-clean if started
insserv: loop involving service dns-clean at depth 1
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
dpkg: error processing package util-linux (--configure):
subprocess installed post-installation script returned error exit status 1
util-linux
I have been told -
the problem is that you are stuck at the boot sequencing.
Here is what I see when I viewed the file [runlcactivator]
Now please suggest how do I "completely purge the program and scripts from /etc/init.d/ and /etc/rc? files." - as is suggested in the answer? What is the command line to do this?
I am not familiar with codes, so if instructions are specific I can just follow them as it is. Thanks for helping!
