Whenever I install something I get one of two things
$ sudo apt-get install netflix-desktop
will result in
Reading package lists... Done
Building dependency tree
E: Unable to locate package netflix-desktop'
or
$ sudo apt-get install -fy
will result in
apache2
cups-daemon
mysql-server-5.7
bluez
cups-core-drivers
cups
bluez-cups
mysql-server
I'm sure that those particular applications are corrupted but I have no idea on how I should remove/replace/repair.
EDIT
This is the start of the full output - there's about 140k characters of
.depend.start
.depend.boot
.depend.stop
.depend.start
etc.etc.etc.
0 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
8 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up apache2 (2.4.18-2ubuntu3.4) ...
insserv: warning: script 'K20.depend.start' missing LSB tags and overrides
insserv: warning: script 'K20.depend.boot' missing LSB tags and overrides
insserv: warning: script 'K20.depend.stop' missing LSB tags and overrides
insserv: There is a loop between service plymouth and urandom if started
insserv:  loop involving service urandom at depth 4
insserv:  loop involving service hwclock at depth 3
insserv: There is a loop between service .depend.start and udev if started
insserv:  loop involving service udev at depth 1
insserv: There is a loop at service .depend.start if started
insserv: There is a loop at service plymouth if started
insserv:  loop involving service networking at depth 6
insserv:  loop involving service mountdevsubfs at depth 3
insserv:  loop involving service mountkernfs at depth 1
insserv: Starting .depend.start depends on plymouth and therefore on system facility `$all' which can not be true!
insserv: Starting .depend.boot depends on plymouth and therefore on system facility `$all' which can not be true!
insserv: Starting .depend.stop depends on plymouth and therefore on system facility `$all' which can not be true!
Zanna
  • 72,312
