As you said, you can't remove this repository with purging or removing skypeforlinux package.
You should remove that repository file manually.
Skype make its repository's file in /etc/apt/sources.list.d directory with skype-stable.list name.
So you should comment all lines of this file with this command:
sudo sed -i 's/^/#/' /etc/apt/sources.list.d/skype-stable.list
And then run this command to apply changes in your repositories:
sudo apt update
Also you can remove that file completely with this command, but the above way (comment all lines) is much safer than it:
sudo rm -rf /etc/apt/sources.list.d/skype-stable.list
