12
I have Skype installed which I got from the Canonical Partners repository, however after reading this article I have come to understand that I can get this latest Alpha version from a repository too though no such update has come to me via the partner repository I have activated. So I have several questions on this matter:
  1. So from which repository (unless that was just a mistake in the article) do I get it from? Is it available under a different name in the partner repository, or is there another official Skype repository?
  2. If it is the case that there is a more official repository to get this from then when it is no longer Alpha but instead Stable, will I be able to upgrade to it via the partner repository I currently have enabled or is it no longer support in there?
I am running Ubuntu GNOME 16.04 with GNOME 3.20.
  1. Download the Deb package for Skype for Linux Beta with your favourite web browser or HTTP client.
    • For a terminal-based solution use:
      wget https://go.skype.com/skypeforlinux-64.deb
  2. Install the Deb package with your favourite package manager, e. g. Software Center or GDebi.
    • For a terminal-based solution or to debug the package installation use:
      sudo dpkg -i skypeforlinux-64.deb
      sudo apt install -f
  3. You're done! When you installed the package it automatically added the repository
    deb [arch=amd64] https://repo.skype.com/deb stable main
    to the file /etc/apt/sources.list.d/skype-stable.list to keep your installation of Skype up to date via Ubuntu's package update process.
Eliah Kagan
  • 119,640
