Is there a way to set in Kubuntu Oneiric keyboard shortcuts to:
  1. Show the desktop (used to be called "toggle showing desktop" in old versions of Kubuntu but now seems to be gone from the preferences).
  2. Run specific programs (e.g. Winkey+e will start Dolphin, Winkey+t will start Konsole, etc.)
Also, is there a way to disable the transparency of the bottom panel? I don't want to completely disable transparency, only to prevent the panel to change its looks every time my wall changes (I use slideshow).
Gadi A
  • 123
KDE plasma desktop: http://userbase.kde.org/Plasma
1) Do you have the plasma widget / plasmoid "Show Desktop" on your panel ?
With it you could add the shortcut
2) K > Applications > Help >Application Manuals > Settings > Menu Editor
ie. with the Dolphin; Menu Editor - Advanced tab: Current shortcut key
Earlier: How to change color/transparency of all desktop panels?
user26687
  • 15,174
