11
On OSX, I can easily take a picture of desktop using keyboard combinations (Shift-Option-3 or 4). And the images are automatically created in my desktop.
How do I simulate this on Kubuntu?
Thanks
mrjayviper
  • 1,605
Taking a picture of the desktop using keyboard shortcut and the image is automatically saved to the user desktop
Using Spectacle - KDE Framework 5 default screenshot capture utility:
$ spectacle --help
Usage: spectacle [options]
KDE Screenshot Utility
Options:
  -v, --version              Displays version information.
  -h, --help                 Displays this help.
  --author                   Show author information.
  --license                  Show license information.
  --desktopfile <file name>  The base file name of the desktop entry for this
                             application.
  -f, --fullscreen           Capture the entire desktop (default)
  -m, --current              Capture the current monitor
  -a, --activewindow         Capture the active window
  -u, --windowundercursor    Capture the window currently under the cursor,
                             including parents of pop-up menus
  -t, --transientonly        Capture the window currently under the cursor,
                             excluding parents of pop-up menus
  -r, --region               Capture a rectangular region of the screen
  -g, --gui                  Start in GUI mode (default)
  -b, --background           Take a screenshot and exit without showing the GUI
  -s, --dbus                 Start in DBus-Activation mode
  -n, --nonotify             In background mode, do not pop up a notification
                             when the screenshot is taken
  -o, --output <fileName>    In background mode, save image to specified file
  -d, --delay <delayMsec>    In background mode, delay before taking the shot
                             (in milliseconds)
  -w, --onclick              Wait for a click before taking screenshot.
                             Invalidates delay
Command:
spectacle -f -b -n -o "$HOME/Desktop/ScreenShot-$(date +%Y%m%d%H%M%S).jpg"
will capture the entire desktop image to the user Desktop folder aka desktop.
The command can be added to the KDE menu with the KDE menu editor: https://docs.kde.org/stable5/en/kde-workspace/kmenuedit/index.html
The command can be launched with the user defined shortcut:
When the shortcut is clicked the picture is saved to the desktop:
user26687
  • 15,174
  1. Open System Settings -> Keyboard -> Shortcuts
  2. Select Custom Shortcuts
  3. Click Add Custom Shortcut
  4. Fill fields
    • Name to Take a screenshot of region
    • Command to spectacle -r
  5. Click OK
  6. Double-Click one of the unassigned keyboard bindings
  7. Insert your desired binding. (I'm using Super+Shift+S)
Tyler
  • 121
ksnapshot is the KDE (kubuntu) version of screen capture. It can be launched from the menu or by pressing prt scrn button
ravery
  • 6,924
Post configured
You need to add in Global Shortcuts the Spectacle application. This applications has already a few shortcuts (the importante ones) pre configures but empty. Iǘe attached a picture of my configuration
Raffa
  • 34,963
Chubutin
  • 111
