In theory, neither disabling Secure Boot nor enabling BIOS/CSM/legacy-boot support should affect networking once Ubuntu has booted, with one possible exception: If you've switched the actual Ubuntu boot mode from EFI to BIOS, that might affect hardware initialization, which might affect the ability to use the network device. To completely switch boot modes would require installing a BIOS-mode boot loader, though, and you haven't indicated that you've done this.
You can verify your boot mode by looking for a directory called /sys/firmware/efi. If it's present, you've booted in EFI mode; if it's absent, you've booted in BIOS mode. You might make this check, on the off chance that you've completely changed boot modes. Alternatively, you can simply disable your CSM. It's almost certainly doing you no good, and could be slowing down the boot process.
Although Secure Boot is even less likely to be related to your problem, there are ways to enable it and use VirtualBox. There are several questions and answers on this site that address this issue, such as:
Overall, my suspicion is that your networking problem is unrelated to the changes you made. Maybe you're experiencing a temporary network glitch, or your network's DHCP server has crashed. If I'm right, the timing of the problem appearing when it did is coincidental, and you should look elsewhere for a solution. I'm sure there are questions and answers on this site that address such problems, but I don't follow that topic closely, so your search on this topic is as good as mine.
