I installed Katoolin using which I downloaded all the 'Information Gathering' tools. Midway there came a prompt to allow access to DHCP which I allowed. Since then my PC has started misbehaving. Whenever I reboot, either the ethernet is found working or the wifi card. But not both simultaneously. I mean the PC can't even identify the lan cable is connected or not and the Ethernet is shown as unclaimed. I have provided outputs from various commands down below for your convenience.
lspci
00:00.0 Host bridge: Intel Corporation Skylake Host Bridge/DRAM Registers (rev 08)
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 520 (rev 07)
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
00:15.0 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #0 (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
00:17.0 SATA controller: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] (rev 21)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port (rev f1)
00:1d.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #9 (rev f1)
00:1d.2 PCI bridge: Intel Corporation Device 9d1a (rev f1)
00:1d.3 PCI bridge: Intel Corporation Device 9d1b (rev f1)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point-LP LPC Controller (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
01:00.0 3D controller: NVIDIA Corporation Device 179c (rev a2)
03:00.0 Network controller: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter (rev 31)
04:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTL8411B PCI Express Card Reader (rev 01)
04:00.1 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 12)
sudo lshw -class network
*-network
       description: Wireless interface
       product: QCA9377 802.11ac Wireless Network Adapter
       vendor: Qualcomm Atheros
       physical id: 0
       bus info: pci@0000:03:00.0
       logical name: wlp3s0
       version: 31
       serial: 40:49:0f:5a:b3:45
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=ath10k_pci driverversion=4.15.0-32-generic firmware=WLAN.TF.1.0-00002-QCATFSWPZ-5 ip=192.168.1.154 latency=0 link=yes multicast=yes wireless=IEEE 802.11
       resources: irq:131 memory:94200000-943fffff
  *-network UNCLAIMED
       description: Ethernet controller
       product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0.1
       bus info: pci@0000:04:00.1
       version: 12
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd cap_list
       configuration: latency=0
       resources: ioport:3000(size=256) memory:94404000-94404fff memory:94400000-94403fff
UPDATE: I tried removing secure boot from my bios and rebooted Ununtu and the PCI cards worked fine. But when I again turned it off the condition became same as earlier. I would recommend you to read this answer https://askubuntu.com/a/951032/787213
lshw -class Network
*-network
       description: Ethernet interface
       physical id: 0.1
       logical name: enp4s0f1
       version: 12
       serial: 54:ab:3a:b4:76:f4
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8168 driverversion=8.046.00-NAPI duplex=full ip=192.168.1.218 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
       resources: irq:127 ioport:3000(size=256) memory:94404000-94404fff memory:94400000-94403fff
