After reading and reviewing a lot about Ubuntu finally today i installed Ubuntu 16.04 LTS into my laptop. After installation I ran the update and upgrade commands which completed successfully. When I restarted my laptop, it froze at the startup screen.
I pressed the power button for few seconds and turned the laptop off. In the next boot I selected advanced options and found two kernel options:
  • 1st one is 4.10.0-33
  • 2nd one is 4.8.0-38
I am able to start and boot using 4.8.0-38 but not able to start with 4.10.0-36. I have also formatted my laptop twice but i am facing the problem after complete update.
So friends please help me to come out of this problem. I would also like to say that I am very new here.
below is my system details.
Filesystem      Size  Used Avail Use% Mounted on
udev            1.9G     0  1.9G   0% /dev
tmpfs           382M  6.3M  376M   2% /run
/dev/sda2       113G  4.9G  102G   5% /
tmpfs           1.9G   34M  1.9G   2% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           1.9G     0  1.9G   0% /sys/fs/cgroup
tmpfs           382M   80K  382M   1% /run/user/1000
/dev/sda4       200G   72G  129G  36% /media/ali/Software
Thanks in Advance.
My first concern would be the next update installs 4.10.0-37 which is also broken. Then through auto-remove you loose your only working kernel which is 4.8.0-38.
The first thing I would do is install a kernel version which can't be auto-removed and must be manually removed. I would suggest 4.9.45 mainline build because 4.9 is LTS (Long Term Support) for about 5 years I believe.
The instructions for installing a stable mainline kernel are fairly straightforward: What is the lastest stable kernel and how to install it?
Another kernel you can install to test version 4.10 compatibility is 4.10.17 mainline build.
Finally an extra version of 4.8 that can't be removed automatically is 4.8.17 mainline build
Keep in mind each kernel consumes about 50 MB in your /boot directory and about 350 MB in /lib and /etc sub-directories.
Later after auto-installed kernels are working reliably you can remove manually installed kernels. I have lots of disk space and keep about 20 kernels installed for testing purposes but that's not everyone's cup of tea.
Hopefully your problems wiht 4.10.0-36 is a one-off glitch and will never be repeated. First things first though is to protect your system to ensure you can always boot successfully.
Please keep us posted on progress.
