I know that the following command increases volume
amixer -D pulse sset Master 10%+
This command only increases the volume, but does not show any GUI notifications. But, the default Volume Up key also gives GUI and sound notifications.
What commands are called when I press the Volume Up button?
dessert
  • 40,956
I don't know exactly what command is being invoked while pressing volume up button however I believe that it's not a single command. You can simulate and achieve same behavior by using three simple command:
  1. To increase the volume as you know:
  2. To send a notify:
    notify-send Volume volume has been increased by +10
  3. To play a song:
    paplay '/usr/share/sounds/KDE-Window-All-Desktops-Not.ogg'
change the file address with anything you want, you can find different songs at:
/usr/share/sounds/
or run a simple search:
locate .ogg | grep /share
dessert
  • 40,956
Ravexina
  • 57,256
You‘re probably searching for the X On-Screen Display library XOSD. The package is called xosd-bin and the command osd_cat is used to display text, status bars etc. on the screen.
osd_cat -b percentage -P 20 -T Status: -f "-adobe-helvetica-bold-*-*--34-*-*-*-*"
displays
See this German wiki page for options and examples and man osd_cat for more.
As others already pointed out, sounds can be played using a player like aplay, paplay, cvlc, mplayer, cmus, … – Where do I find system sounds?
dessert
  • 40,956
