First, be aware that in EFI mode, the computer doesn't really present options to boot disks; it boots files. (There are sometimes entries for disks that boot the fallback boot loader, EFI/BOOT/bootx64.efi. These are intended for use on removable media, but can be used to boot hard disks in some cases.) When Ubuntu is installed, you should see a new boot entry called ubuntu in the computer's boot manager. It could be that you got such an entry but didn't see it because you were looking for something else, in which case you created problems for yourself when you tried your second install. OTOH, it could also be that a bug in the Ubuntu installer or in your firmware caused the ubuntu entry to not be created. In the latter case, you might want to check the following questions and their answers:
The second two of those mostly apply to dual-boot setups, which I gather you don't have, so they're probably less applicable than the first one.
As to the partition issues, GPT uses more of the disk than does MBR. Thus, if you convert from GPT to MBR using tools that don't know about the GPT data structures, or that just don't bother to erase them, you'll end up with MBR with remnants of the GPT data structures. Some tools, including my own GPT fdisk (gdisk, cgdisk, and sgdisk), will notice this and offer to use the GPT data. This is an intentional design decision to aid in case of damage to the GPT data structures, but it can be confusing if you used a dumb program that didn't completely erase old GPT data structures.
As a general rule, if you boot in BIOS mode, you should use MBR on your disk(s); and if you boot in EFI mode, you should use GPT on your disk(s). Ubuntu is more flexible than this and can boot in BIOS mode from a GPT disk or in EFI mode from an MBR disk, but doing so sometimes causes problems. In multi-boot scenarios, other OSes (particularly Windows) are less flexible. For these reasons, it's best to stick to the conventional MBR/BIOS and GPT/EFI linkages.
Overall, then, I recommend you start over with GPT and EFI-mode booting. Upon reboot, if Ubuntu doesn't boot and you don't see an ubuntu entry in your firmware's boot manager, see the links above (especially the first one) for a solution. If you need more help, be sure to say what brand and model your computer is and when you bought it -- EFIs from certain manufacturers, and especially older ones (say, from 2011 and 2012) tend to be flaky and can require awkward workarounds.
