I have a Dell XPS 13 which, by default, has a very sensitive trackpad. As you are typing, if you brush the trackpad by accident, the trackpad considers it as a click and the text insertion point jumps to wherever the mouse happens to be. I found and installed this fix for this issue:
sudo apt-get install xserver-xorg-input-libinput
However, now the scrolling is unnatural. When I use the trackpad to scroll a long document, it is the viewport that moves over the content. I want the content to move in the same direction as my fingers, just as it did before, just like on a touchscreen.
Can you explain to me what changes I should make to the files at /usr/share/X11/xorg.conf.d/ that will make this happen?
The solution proposed here did not help.
James Newton
  • 1,145
  • 17
  • 31
Edit the file /usr/share/X11/xorg.conf.d/40-libinput.conf or 90-libinput.conf depending on your HWE stack.
Add to the end of the touchpad section of the file a line
Option "NaturalScrolling" "True"
and restart the session.
The section should look this way:
Section "InputClass"
        Identifier "libinput touchpad catchall"
        MatchIsTouchpad "on"
        MatchDevicePath "/dev/input/event*"
        Driver "libinput"
EndSection
You can also add Option "Tapping" "True", if you want to enable tap to click feature.
Pilot6
  • 92,041
If anyone prefers not to restart their X server you can do this with xinput.
  1. Run xinput --list
  2. Note the identifier of your trackpad
  3. Run xinput --list-props <trackpad identifier>
  4. Note the identifier of the natural scrolling parameter
  5. Run xinput --set-prop <trackpad identifier> <natural scrolling parameter> 1
For example, on my system I run
xinput --set-prop "CUST0001:00 06CB:76B1 Touchpad" "libinput Natural Scrolling Enabled" 1
