I just run an apt-get upgrade on my Ubuntu 16.04 installation and I am getting this error:
Do you want to continue? [Y/n] Y
Setting up shim-signed (1.32~16.04.1+0.9+1474479173.6c180c6-1ubuntu1) ...
Installing for x86_64-efi platform.
grub-install: error: /boot/efi doesn't look like an EFI partition.
dpkg: error processing package shim-signed (--configure):
subprocess installed post-installation script returned error exit status 1
shim-signed
The output of df -h is
polesemi@pcsensori34:~$ df -h
Filesystem Size Used Avail Use% Mounted on
udev 7,8G 0 7,8G 0% /dev
tmpfs 1,6G 9,5M 1,6G 1% /run
/dev/sdb1 213G 135G 68G 67% /
tmpfs 7,8G 316M 7,5G 4% /dev/shm
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
tmpfs 7,8G 0 7,8G 0% /sys/fs/cgroup
polesemi@login.dei.unipd.it:/home/polesemi 5,7T 2,1T 3,6T 37% /home/polesemi/homeDei
polesemi@login.dei.unipd.it:/nfsd/signet/ns/polese 475G 266G 210G 56% /home/polesemi/nsDei
tmpfs 1,6G 108K 1,6G 1% /run/user/1000
The output of parted is
polesemi@pcsensori34:~$ sudo parted -l
[sudo] password for polesemi:
Model: ATA ST500DM002-1SB10 (scsi)
Disk /dev/sda: 500GB
Sector size (logical/physical): 512B/4096B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 32,3kB 41,1MB 41,1MB primary fat16 diag
2 41,9MB 12,6GB 12,6GB primary ntfs boot, diag
3 12,6GB 500GB 487GB primary ntfs
Model: ATA KINGSTON SHSS37A (scsi)
Disk /dev/sdb: 240GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
3 1049kB 212MB 211MB fat32 efi boot, esp
1 212MB 232GB 232GB ext4
2 232GB 240GB 8000MB linux-swap(v1)
What can I do to fix it? Thanks.
