Please refer to below logs. I am facing this issue after I upgraded from 18.10 to 19.04 Ubuntu, Please suggest me fix. Thanks.
royal:~$ sudo apt upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up grub-efi-amd64-signed (1.115+2.02+dfsg1-12ubuntu2) ...
Installing for x86_64-efi platform.
Could not prepare Boot variable: Function not implemented
grub-install: error: efibootmgr failed to register the boot entry: Input/output error.
dpkg: error processing package grub-efi-amd64-signed (--configure):
 installed grub-efi-amd64-signed package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of shim-signed:
 shim-signed depends on grub-efi-amd64-signed | grub-efi-arm64-signed; however:
  Package grub-efi-amd64-signed is not configured yet.
  Package grub-efi-arm64-signed is not installed.
dpkg: error processing package shim-signed (--configure):
 dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
 shim-signed
I've came across this issue after upgrading from 18.10 to 19.04 using sudo apt dist-upgrade. GRUB was not working, fortunately, my Ubuntu was booting, possibly it was recognized by EFI mechanizm.
My research led to the conclusion that the reason for this error must be in a newer version of libefivar1 library. I've downgraded it to the latest version provided for Ubuntu 18.10 along with it's dependencies.
First, I went to Ubuntu Packages and downloaded the following packages for cosmic release to a separate folder, for example grub fix:
  1. grub-efi-amd64-bin
  2. grub-efi-amd64-signed
  3. grub-common
  4. grub-pc
  5. grub-pc-bin
  6. grub2-common
  7. os-prober
  8. grub-gfxpayload-lists
  9. libefivar1
  10. efibootmgr
  11. efivar
After that I removed those packages in the newest versions delivered with 19.04 disco release:
sudo apt remove grub-efi-amd64-bin grub-efi-amd64-signed grub-common grub-pc grub-pc-bin grub2-common os-prober grub-gfxpayload-lists libefivar1
And installed previously downloaded packages for cosmic release:
cd grub\ fix/
sudo dpkg -i *.deb
Finally, it's a good idea to prevent them from upgrading:
sudo apt-mark hold grub-efi-amd64-bin grub-efi-amd64-signed grub-common grub-pc grub-pc-bin grub2-common os-prober grub-gfxpayload-lists libefivar1
After a permanent fix is provided by the Ubuntu developers, the following should upgrade the packages to the latest 19.04 version:
sudo apt-mark unhold grub-efi-amd64-bin grub-efi-amd64-signed grub-common grub-pc grub-pc-bin grub2-common os-prober grub-gfxpayload-lists libefivar1
sudo apt upgrade
If you are not able to boot up your freshly installed Ubuntu 19.04 at all, maybe you can combine my steps with steps from this answer using live Ubuntu 19.04 or just use those steps on 18.10 to make Ubuntu booting again.
