I have an HP ProBook 4431s.
After installing ubuntu 16.04 LTS, my WiFi is really slow so I have to use the LAN for now.
I tried the all the thread on Ubuntu where you select the realtek antenna after downloading Larry Finger's github repo.
My WiFi is still slow. I didn't see any improvements.
The output of ubuntu's wireless info is here:
https://paste.ubuntu.com/25350005/
I realized that my adapter was intel. After re-installing Ubuntu, the output is as follows:
https://paste.ubuntu.com/25353321/
FYI, I used to do dual boot between Windows 7 and ubuntu 12.04 LTS and everything was fine. This is due to the upgrade to 16.04 LTS.
Pilot6
  • 92,041
Run in a terminal
sudo tee /etc/modprobe.d/iwlwifi-opt.conf <<< "options iwlwifi 11n_disable=8"
and reboot.
Pilot6
  • 92,041
In your paste, we see several SSIDs named BELL101, including the one to which you are connected. I suspect that your wireless drops because it is attempting to roam to another instance of BELL101. If this is a router for which you have administrative access, I suggest that you rename it to, for example, BELL105 as it is a 5 gHz access point.
If you are unable to rename it, I suggest that you bind to the specific instance of BELL101 by MAC address, like this: Ubuntu connect drops. Worked for a while then started dropping again
chili555
  • 61,330
I tried a combination of the above two solutions:
1) Changed the name of the wifi from something generic like BELL101 to VINEET101
2)
sudo tee /etc/modprobe.d/iwlwifi-opt.conf <<< "options iwlwifi 11n_disable=1"
it got my internet speed from 0.3 Mbps tp 21 Mbps. It still doesn't go to 80-90 Mbps like it usually does but it is at least something I can work with. If you have any further ideas about how to increase this value, please let me know.
