I am using Ubuntu 16.04. Ubuntu ships with some gnome-screenshot, which can take screenshots of both the entire screen and screen parts. Unfortunately, it doesn't work if some menu is activated, i.e. I can't take a screenshot of a dropdown menu. In other cases the menu is closed when I press Shift+PrtScn.
This is an imperfection which Greenshot does not have.
Is there a normal screenshot application in Ubuntu which can capture everything, including menus?
karel
  • 122,292
  • 133
  • 301
  • 332
Dims
  • 1,861
I suggest you to use Shutter. It works with any flavor of Ubuntu.
You can install it with apt or apt-get in all currently supported versions of Ubuntu:
sudo apt install shutter
If you prefer, you can set it as default PrtScr shortcut app in Ubuntu/Unity and in Lubuntu
To make capturing a windows dropdown menu easier give yourself 3 seconds of additional time to show the windows dropdown menu after selecting the window that gets a screenshot of it taken. Select Edit -> Preferences -> in left pane select Main -> in the number picker after where it says Capture after a delay of select 3 seconds.
Redbob
  • 1,686
I know it's been quite a long time, but in case you didn't solve it, I had the same problem and I found the solution in the pre-installed software in Ubuntu, notably the "Screenshot" app (it should be under "Activities", or "Accessories").
This will let you print a desired region of the screen. You'll need to see or set the triggering actions under the "Keyboard" system section, "Shortcut" tab (I had the Shift-PrnScreen on default). There are also a number of other options.
zx485
  • 2,865
Andrea
If you don't want to install a GUI program, you can just use scrot (sudo apt install scrot). To make a screenshot of the whole screen after five seconds (-d 5) and save it to ~/screenshot.png execute in a terminal:
scrot -d 5 ~/screenshot.png
To make the screenshot of the (to that time) active window (-u) including its border (-b) after five seconds and save it to ~/screenshot.png execute:
scrot -u -b -d 5 ~/screenshot.png
Read more on scrot's manpage.
dessert
  • 40,956
I know i'm late for this but I thought may be it will help another person who will face this kind of problem so for this purpose use built-in app named "SCREENSHOT". I'm using UBUNTU BUDGIE 18.04 LTS 64-bit, and this application will also be present in UBUNTU 18.04. Hope so it will help you.
