I'm new to Ubuntu.
I'm trying to install a new application but unmet dependency errors have arisen.
After entering the command sudo apt-get install, I get this error:
You might want to run 'apt-get -f install' to correct these:
linux-image-extra-4.4.0-87-generic : Depends: linux-image-4.4.0-87-generic but it is not going to be installed
linux-image-extra-4.4.0-92-generic : Depends: linux-image-4.4.0-92-generic but it is not going to be installed
linux-image-generic : Depends: linux-image-4.4.0-92-generic but it is not going to be installed
Recommends: thermald but it is not going to be installed
However, after I had run the command sudo apt-get -f install, it still has the same unmet dependencies error:
dpkg: error processing archieve/var/cache/apt/archives/linux-image-4.4.0-92-generic.dpkg: erro processing archives /var/cache/apt/archieves/linux-image-4.4.0-92-generic_4.4.0-92.115_amd64.deb (--unpack):
cannot copy extracted data for './boot/abi-4.4.0-92-generic' to '/boot/abi-4.4.0-92-generic-new': failed to written because the error message indicates a disk full error
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
^[[BExamining /etc/kernel/postrm.d
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.4.0-92-generic /boot/vmlinuz-4.4.0-92-generic
run-parts:executing /etc/kernel/postrm.d/zz-update-grub 4.4.92-generic /boot/vmlinuz-4.4.0-92generic
Errors were encounted while processing:
/var/cache/apt/archives/linux-image-4.4.0-92-generic_4.4.0-92.115_amd64.deb
