I tried to install Microsoft Fonts through the terminal and now LibreOffice Writer will not work!
I was trying to get Times New Roman on LibreOffice Writer, so I used the command:
sudo apt-get install ttf-mscorefonts-installer
The terminal ran it and everything "finished" but nothing happened. I tried to open LibreOffice Writer and it would display the icon LibreOffice 5 before disappearing and not opening the program. I thought that it was the installer's doing, so I ran the code to supposedly get rid of it. That code/command was:
sudo apt-get remove ttf-mscorefonts-installer
Now I'm sitting here, trying to get it to work, but I'm getting the same results.
For reference, when I used the first command the following appeared:
Reading package lists... Done
Building dependency tree
ttf-mscorefonts-installer is already the newest version (3.4+nmu1ubuntu2).
The following packages were automatically installed and are no longer required:
gyp lib32gcc1 lib32stdc++6 libc6-i386 libjs-inherits libjs-node-uuid
libssl-dev libssl-doc libuv1-dev node-abbrev node-ansi node-ansi-color-table
node-archy node-async node-block-stream node-combined-stream node-cookie-jar
node-delayed-stream node-forever-agent node-form-data node-fstream
node-fstream-ignore node-github-url-from-git node-glob node-graceful-fs
node-gyp node-inherits node-ini node-json-stringify-safe node-lockfile
node-lru-cache node-mime node-minimatch node-mkdirp node-mute-stream
node-node-uuid node-nopt node-normalize-package-data node-npmlog node-once
node-osenv node-qs node-read node-read-package-json node-request node-retry
node-rimraf node-semver node-sha node-sigmund node-slide node-tar
node-tunnel-agent node-underscore node-which nodejs-dev npm zlib1g-dev
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 483 not upgraded.
When I entered the command to remove it, it displayed this:
The following packages will be REMOVED:
0 upgraded, 0 newly installed, 1 to remove and 483 not upgraded.
After this operation, 134 kB disk space will be freed.
Do you want to continue? [Y/n] Y
(Reading database ... 247063 files and directories currently installed.)
Removing ttf-mscorefonts-installer (3.4+nmu1ubuntu2) ...
Processing triggers for update-notifier-common (3.168.4) ...
What do I do to fix this? I have a lot of documents made with LibreOffice Writer and I don't want to lose them!
