I have Calligra Words, Version 2.9.7, Using KDE Development Platform 4.14.22 from the standard repo of Kubuntu 16.04.
I was looking at ~/.kde/share/config/wordsrc and saw an entry like this: ko_geometry=AdnQywABAAD////6AAAANQAABRAAAALLAAAAAAAAAFoAAAUKAAACxQAAAAAAAA==
The next line relates to ko_windowstate and is much longer but similar to the stuff that follows ko_geometry= in the code above.
ko_windowstate=AAAA/wAAAAD9AAAAAgAAAAEAAAULAAACKvwCAAAADPsAAAAOAFQAbwBvAGwAQgBvAHgBAAAAGAAAAGMAAAAAAAAAAPsAAAAgAHMAaABhAHIAZQBkAHQAbwBvAGwAZABvAGMAawBlAHIAAAAAQgAAAGIAAABiAQAAA/sAAAAqAFMAaABhAHAAZQBDAG8AbABsAGUAYwB0AGkAbwBuAEQAbwBjAGsAZQByAAAAAEIAAAJ0AAAAHAAAABz7AAAAIgBTAHQAcgBvAGsAZQAgAFAAcgBvAHAAZQByAHQAaQBlAHMAAAAAAP////8AAAAAAAAAAPsAAAAWAFMAdAB5AGwAZQBEAG8AYwBrAGUAcgAAAAKSAAAAcAAAAAAAAAAA+wAAACAAUwBoAGEAcABlACAAUAByAG8AcABlAHIAdABpAGUAcwAAAAAA/////wAAABwBAAAD+wAAACIAUwBoAGEAZABvAHcAIABQAHIAbwBwAGUAcgB0AGkAZQBzAAAAAAD/////AAAAAAAAAAD7AAAAFABTAHQAYQB0AGkAcwB0AGkAYwBzAAAAAAD/////AAAA7gEAAAP7AAAABgBSAGQAZgAAAAAA/////wAAAGgBAAAD+wAAABQATgBhAHYAaQBnAGEAdABpAG8AbgAAAAAA/////wAAAGgBAAAD+wAAACgAUwBuAGEAcABHAHUAaQBkAGUAIABQAHIAbwBwAGUAcgB0AGkAZQBzAAAAAAD/////AAAAHAEAAAP7AAAADgBNAG8AZABlAEIAbwB4AQAAAEIAAAIqAAAAqQAIABsAAAACAAAAAAAAAAD8AQAAAAH7AAAAGgBUAG8AbwBsAEIAYQByAEQAbwBjAGsAZQByAAAAAAD/////AAAAAAAAAAAAAAAAAAACBQAAAAQAAAAEAAAACAAAAAj8AAAAAQAAAAIAAAABAAAAFgBtAGEAaQBuAFQAbwBvAGwAQgBhAHIBAAAAAP////8AAAAAAAAAAA==
What sort of information is contained in such strings?
George Udosen
  • 37,534
DK Bose
  • 44,553
KDE configuration files
Earlier AskUubntu: Configuration files in a KDE application
Now KDE Frameworks KConfig: https://api.kde.org/frameworks/kconfig/html/
Calligra 2.9.7
...calligra-2.9.7/libs/main/KoMainWindow.cpp line 444:
KConfigGroup cfg(KGlobal::config(), "MainWindow");
cfg.writeEntry("ko_geometry", saveGeometry().toBase64());
cfg.writeEntry("ko_windowstate", saveState().toBase64());
The Calligra is saving the window geometry and the window state (what widgets are open and where they are etc...) to the rc files as base 64: https://en.wikipedia.org/wiki/Base64 .
Deconding your ko_windowstate snippet - https://www.base64decode.org:
user26687
  • 15,174
