I tried to install my Brother MFC-7225N scanner in Lubuntu 16.04 64 bit following the instructions here, but I only get the error “Invalid argument”.
What I did
- install the driver
brscan2-0.2.5-1.amd64.debas well as the scan-key-toolbrscan-skey-0.2.4-1.amd64.deband the udev rule packagebrother-udev-rule-type1-1.0.0-1.all.debfrom here add the following lines to
/lib/udev/rules.d/60-libsane.rules, trying one at a time:ATTRS{idVendor}=="04f9", ATTRS{idProduct}=="0186", MODE="0660", GROUP="scanner", ENV{libsane_matched}="yes" ATTRS{idVendor}=="04f9", ATTRS{idProduct}=="0186", MODE="0664", GROUP="scanner", ENV{libsane_matched}="yes" ATTRS{idVendor}=="04f9", ATTRS{idProduct}=="0186", MODE="0666", GROUP="scanner", ENV{libsane_matched}="yes"copy files over:
sudo cp /usr/lib64/sane/* /usr/lib/sane/ sudo cp /usr/lib64/libbr* /usr/lib/create
brother.conffiles:echo -e "/usr/lib64\n/usr/lib64/sane" | sudo tee /etc/ld.so.conf.d/brother.conf && sudo ldconfig echo "usb 04f9 0186" | sudo tee /etc/sane.d/brother.confrun the setup program:
sudo /usr/local/Brother/sane/setupSaneScan2 -i
What I get
> brscan-skey
> brscan-skey -l
MFC-7225N : brother2:bus2;dev1 : USB Active
> scanimage -L
device `bus2;dev1' is a Brother MFC-7225N USB scanner
> scanimage -T
scanimage: open of device bus2;dev1 failed: Invalid argument
> simple-scan -d
[+5,91s] DEBUG: simple-scan.vala:404: Requesting scan at 300 dpi from device 'bus2;dev1'
[+5,91s] DEBUG: scanner.vala:1560: Scanner.scan ("bus2;dev1", dpi=300, scan_mode=ScanMode.COLOR, depth=8, type=ScanType.SINGLE, paper_width=0, paper_height=0, brightness=0, contrast=0)
[+5,91s] DEBUG: scanner.vala:803: Processing request
[+5,91s] DEBUG: scanner.vala:864: sane_open ("bus2;dev1") -> SANE_STATUS_INVAL
[+5,91s] WARNING: scanner.vala:868: Unable to get open device: Invalid argument
Some more information
> lsusb
Bus 002 Device 004: ID 138a:0017 Validity Sensors, Inc. Fingerprint Reader
Bus 002 Device 009: ID 04f9:0186 Brother Industries, Ltd Composite Device
> sudo sane-find-scanner
found USB scanner (vendor=0x138a, product=0x0017) at libusb:002:004
found USB scanner (vendor=0x04f9, product=0x0186) at libusb:002:009
could not fetch string descriptor: Pipe error
> cat /etc/sane.d/dll.conf
brother2
> cat /etc/sane.d/brother.conf
usb 04f9 0186
