I had the scanner working in Ubuntu 12.04, but now when I try to launch xsane, I get a scanner not found error: brsaneconfig4 -q | grep 7065 produces the following output:
144 "DCP-7065DN"
0 DCP-7065DN          "DCP-7065DN"        I:192.168.1.11
Edit: The problem was with setting a manual IP on the scanner. If I assign the IP address via DHCP, the scanner works!
Jorge Castro
  • 73,717
Eric Truett
  • 1,067
Visit the page linked below:
Printer Driver | Downloads | DCP-7065DN | United States | Brother - linux-brprinter-installer-2.2.1-1.gz
Select Linux and .deb then click search
Download the Driver Install tool.
Open with file roller(aka archive manager) and extract to your home directory.
Open Files, Click on Home
right click on linux-brprinter-installer-2.1.1-1 go to properties, permissions and check the box allow executing as program or after opening the terminal as described below issue the command chmod +x ./linux-brprinter-installer-2.1.1-1
Open a terminal with CtrlAltt
issue the commands:
sudo su
./linux-brprinter-installer-2.2.1-1
at Input Model Name enter DCP-7065DN
You will be presented with:
You are going to install following packages.
   dcp7065dnlpr-2.1.0-1.i386.deb
   cupswrapperDCP7065DN-2.0.4-2.i386.deb
   brscan4-0.4.7-1.amd64.deb
   brscan-skey-0.2.4-1.amd64.deb
Agree to this.
You will then be asked to agree to their terms several times. Respond in the affirmative. After a short delay it will ask if you will specify the device URI specify yes – prompted with a number of choices I chose the IP option (12 or 10 in my case)
Enter IP address of printer. (You can set this via the front panel of the printer see note below)
Press Enter when prompted
Note: The leading zeros required on the printer setup will break the sane configuration if you include them so strip them out. example (printer ip 192.168.015.024 = script input 192.168.15.24) otherwise you get this:
PING 192.168.015.024 (192.168.13.20) 56(84) bytes of data.
--- 192.168.015.024 ping statistics ---
11 packets transmitted, 0 received, 100% packet loss, time 9999ms
If this happens to you, use brsaneconfig4 to fix it by removing the faulty configuration with
brsaneconfig4 -r DCP7065DN
and then re-adding it with for example (your IP will likely be different)
brsaneconfig4 -a name=DCP7065DN model=DCP7065DN ip=192.168.15.24
Note: I'm leaving the hyphen out of the model number, for some reason i had issues when I left them in.
Printing and scanning via SimpleScan or Xsane now functions
Tested on Ubuntu 14.04 32-bit and 64-bit as well as 16.04 64-bit and 18.04 64 bit. Note: for 18.04 if you want to use xsane rather than Simple Scan you'll have to install it first with sudo apt install xsane
Elder Geek
  • 36,752
Brother DCP-7065DN, Ubuntu 14.04 64bit: Can print to network printer but cannot use the scan function
This is my more step by step version of getting this scanner going.
The Tick
  • 183
