I'm trying to get my F9 key to function as the dead_greek compose character. It's not working.
I have a custom keyboard layout in /usr/share/X11/xkb/symbols/us called mine. It has this entry for the F9 key:
key <FK09> { [ dead_greek, dead_greek, dead_greek, dead_greek ] };
I have other characters in thsi file as well, so I know the file is being used. I can also run xmodmap -pke | grep dead_greek and get this output:
keycode 75 = dead_greek dead_greek dead_greek dead_greek dead_greek dead_greek XF86Switch_VT_9 dead_greek dead_greek XF86Switch_VT_9
The dead_greek key is there, but none of the Compose combinations work. If I type dead_greek + a for example I just a, not α. This combination is listed in the /usr/share/X11/locale/en_US.UTF-8/Compose file, which I presume I'm using since other compose sequences from there work (but I'm positive as I don't know how to check which Compose file is in ue).
Why is my F9 not working as a dead_greek compose key?
For debugging I also ran xev and pressed F9. I get the output state 0x10, keycode 75 (keysym 0xfe8c, dead_greek), same_screen YES, indicating at least it is partially working, just not working as a greek compose key.
I'm using KDE in case that makes a difference. I also have multiple keyboard layouts, but the output from xmodmap shows dead_greek in all of the layouts.
