18
I've been at trying to do this for the last several hours with no progress.
I'm running Ubuntu 16.04 and I want to disable the sleep/suspend at the login screen (before logging in with any user) so that the display stays active. The suspension/sleep starts after 5 minutes -- a setting I can't seem to find anywhere.
Things that I've tried:
GUI
Done for both (all) users:
  • Never suspend under Power
  • Never turn screen off under Brightness and Lock.
Terminal
gsettings set org.gnome.desktop.session idle-delay 0
sudo /bin/systemctl mask sleep.target suspend.target hibernate.target hybrid-sleep.target
xset s noblank
xset s off
xset dpms force off
xset -dpms
crontab -e:
added
@reboot sudo /bin/systemctl mask sleep.target suspend.target hibernate.target hybrid-sleep.target
@reboot /usr/bin/xset s noblank
@reboot /usr/bin/xset s off
@reboot /usr/bin/xset dpms force off
@reboot /usr/bin/xset -dpms
dconf org.gnome.settings-daemon.plugins.power
critical-battery-action nothing
idle-dim false
lid-close-ac-action nothing
lid-close-battery-action nothing
sleep-inactive-ac-timeout 0
sleep-inactive-ac-type nothing
sleep-inactive-battery-timeout 0
sleep-inactive-battery-type nothing
time-critical 36000
time-low 36000
(The computer has neither lid nor battery btw)
sudo gedit /etc/X11/xorg.conf
Added
Section "ServerFlags"
  Option "BlankTime" "0"
  Option "StandbyTime" "0"
  Option "SuspendTime" "0"
  Option "OffTime" "0"
EndSection
Caffeine
Added
@reboot /usr/bin/caffeine &
in crontab. Also thought about doing the same with
@reboot /usr/bin/caffeine -t 36000
but
caffeine -t 36000
returns
usage: caffeinate [-h] [-V] COMMAND [ARGUMENT [ARGUMENT ...]]
caffeinate: error: unrecognized arguments: -t
acpi
Don't have it.
Any help would be much appreciated!
JohanPI
  • 351
I had the same issue and found the solution in this forum thread. Setting the appropriate value using gsettings worked for me. Note that this needs to be set for the lightdm user, not for your own account or for root. Maybe this was your problem?
Here are the commands you need to run:
sudo su
su lightdm -s /bin/bash
dbus-launch gsettings set org.gnome.settings-daemon.plugins.power sleep-inactive-ac-timeout 0
exit
exit
Note that this only disables sleep for the machine when on AC power. Since I am using a desktop machine, this was sufficient. If you also want to disable sleeping when on battery power, you also need to set the sleep-inactive-battery-timeout value to 0.
After your have run these commands, restart LightDM and you should be good to go.
sudo service lightdm restart
Chris
  • 357
I found a solution from here https://askubuntu.com/a/543861/718511, though they wanted to do the reverse so it's slightly modified. Essentially a script is made to disable dpms and lightdm told to run it.
In /etc/lightdm/lightdm.conf.d/ make a file 50-dpms.conf:
sudo nano /etc/lightdm/lightdm.conf.d/50-dpms.conf
Add the lines
[SeatDefaults]
display-setup-script=/usr/local/bin/dpms-stop
Close the file
In /usr/local/bin/ create a file dpms-stop:
sudo nano /usr/local/bin/dpms-stop
Add the lines
#!/bin/sh
sudo xhost +si:localuser:lightdm # grants localuser rights to X session
sudo su lightdm -s /bin/bash <<HERE
/usr/bin/xset -dpms
exit
HERE
Close the file
Make the file executable:
sudo chmod +x /usr/local/bin/dpms-stop
At reboot it worked for me.
Kevin
  • 1,031
JohanPI
  • 351
The only thing that worked for me was JohanPI's answer, but I had to modify it to turn off the screen saver as well. The modified script looks like this:
#!/bin/sh
/usr/bin/xset -dpms
/usr/bin/xset s off
exit
HERE
Costa
  • 81
Answer by @Costa guided me into the right direction, but his solution wasn't working for me. I do not think (after many tries and errors) lightdm user needs to be configured for that, as root user is the one owning the seat.
So using the same technique with a script running after the X server has started, display-setup-script, here is my script:
#!bin/bash
xset dpms 0 0 0 xset -dpms xset s 0 0 xset s off
I had to set the DPMS & Screensaver timing because just setting thoses "off" wasn't enough...
