I'm completely new to linux. If someone could make out from the image whats wrong it would be really helpful. Also I'm getting that red icon on the top panel.
I tried running these code :-
sudo apt-get clean
cd /var/lib/apt
sudo mv lists lists.old
sudo mkdir -p lists/partial
sudo apt-get clean
sudo apt-get update
The above code made that red icon go away after I rebooted but when I used the sudo apt-get upgrade after using sudo apt-get update command it popped up back again.
sudo apt-get -f install gives me this output error
Also I have referred to this thread (How do I resolve unmet dependencies after adding a PPA?) but to no avail.
After running the sudo dpkg -- configure -a it gives me following error.
instincts@Instincts:~$ sudo dpkg --configure -a
[sudo] password for instincts:
dpkg: dependency problems prevent configuration of ppa-purge:
ppa-purge depends on aptitude.
dpkg: error processing package ppa-purge (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of aptitude:i386:
aptitude:i386 depends on libapt-pkg4.12 (>= 0.8.16~exp12ubuntu6).
aptitude:i386 depends on libboost-iostreams1.46.1 (>= 1.46.1-1).
aptitude:i386 depends on libc6 (>= 2.4).
aptitude:i386 depends on libcwidget3.
aptitude:i386 depends on libept1.4.12.
aptitude:i386 depends on libgcc1 (>= 1:4.1.1).
aptitude:i386 depends on libncursesw5 (>= 5.6+20070908).
aptitude:i386 depends on libsigc++-2.0-0c2a (>= 2.0.2).
aptitude:i386 depends on libsqlite3-0 (>= 3.6.5).
aptitude:i386 depends on libstdc++6 (>= 4.6).
aptitude:i386 depends on libtinfo5.
aptitude:i386 depends on libxapian22.
dpkg: error processing package aptitude:i386 (--configure):
ppa-purge
aptitude:i386
Any help would be appreciated. Thank you.
muru
  • 207,228
You can try fixing the broken dependencies using the following command:
Then run this again:
You can find in details how to fix the dependency error in this thread.
Russo
  • 1,908
Try this:
apt-get update
apt-get upgrade
and if you are running latest Ubuntu
apt-get dist-upgrade
and then
apt-get -f install
pa4080
  • 30,621
FK-VH
  • 188
-1
I reinstalled ubuntu and obviously it solved the error.
