i have installed a program via github in:
/home/user/folder/program.
to get this to run via the terminal i use the following commands.
cd folder
sudo ./program
but i would like to have a short cut and tried to make one via alacarte.
filled in the following data:
name: programname (is not the same as the actual name of the program in the folder)
command: /home/user/folder/program.
icon: changed the icon into a local file. icon.ico
clicked the: launch in terminal?
i now find the "programname" with the correct icon but when i try to run it a icon appears in the nautilus taskbar that starts to blink for a while and then disappears. Also no terminal is opened.
i assume this has to do with an error in the command line: just don't know how to correct it.
hope someone is willing to enlighten me on my error.
Kind regards
Matthieu
You can take inspiration from the similar question here.
You can call the application in the .desktop file as:
# Exec= gksudo -k -u root <absolute path to your executable>
Exec= gksudo -k -u root /home/user/folder/program
AmeyaVS
  • 596
  • 15
