I have Windows 10 and Ubuntu 17.04 on dual boot (120Gb SSD, 100 for windows and the rest for Linux).
When I installed Ubuntu in the second partition, I did not create any swap partition (I have 4Gb of ram and most forums said that with 4Gb+ you do not need swap), so I just created a root partition / with all the 20gb available and selected to encrypt my Home folder only.
The thing is that it's taking 1-2min to boot Ubuntu, while windows boots up in around 10 seconds or less.
I saw some posts here about this issue but most of the cases the OP had the swap partition created, and this is not my case.
What can I do? Install it again and create a swap partition this time or do I take another approach? I'm not tech savvy regarding Ubuntu, so I'd appreciate if you guys show me some steps do identify the issue, thanks!
EDIT #1
My Windows 10 is not set with fastboot because I can access all files/folders of Windows partition inside Linux.
EDIT #2
Output from sudo fdisk -l :
Disk /dev/loop0: 80,5 MiB, 84393984 bytes, 164832 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop1: 76 MiB, 79683584 bytes, 155632 sectors
Disk /dev/sda: 111,8 GiB, 120034123776 bytes, 234441648 sectors
Disklabel type: dos
Disk identifier: 0x39380a4e
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 2048 1026047 1024000 500M 7 HPFS/NTFS/exFAT
/dev/sda2 1026048 193478655 192452608 91,8G 7 HPFS/NTFS/exFAT
/dev/sda3 193480702 234440703 40960002 19,5G 5 Extended
/dev/sda5 193480704 234440703 40960000 19,5G 83 Linux
Disk /dev/sdb: 931,5 GiB, 1000204138496 bytes, 1953523708 sectors
Disklabel type: dos
Disk identifier: 0x2de2a99a
/dev/sdb1 2048 1953519615 1953517568 931,5G 7 HPFS/NTFS/exFAT
Output from systemd-analyze :
Startup finished in 5.074s (kernel) + 3min 514ms (userspace) = 3min 5.588s
Output from systemd-analyze blame :
7.518s NetworkManager-wait-online.service
3.920s fwupd.service
3.015s iio-sensor-proxy.service
1.217s dev-sda5.device
739ms apt-daily.service
EDIT #3:
Output from systemd-analyze critical-chain :
graphical.target @1min 38.007s
└─multi-user.target @1min 38.007s
└─virtualbox.service @1min 37.938s +68ms
└─network-online.target @1min 37.937s
└─NetworkManager-wait-online.service @1min 30.418s +7.518s
└─NetworkManager.service @1min 30.306s +105ms
└─dbus.service @1min 30.281s
└─basic.target @1min 30.273s
└─sockets.target @1min 30.273s
└─snapd.socket @1min 30.265s +8ms
└─sysinit.target @1min 30.264s
└─apparmor.service @193ms +264ms
└─local-fs.target @190ms
└─media-gdf897g6f9-HD\x20TOURO.mount @1min 50.061s
└─dev-sdb1.device @1.467s
EDIT #4:
Here's a image of command systemd-analyze plot > test.svg, a huge gap before sysinit.target, not sure what it means.
