I usually stick to a 755 (or rwxr-xr-x) on my web root, but I do not think this is the issue you're running into since your directory is already set to that. nginx should have access to your directory. The question then becomes the permissions (or existence of) the file you're trying to access. The files within your directory will need to be readable by the user nginx is running as. I usually leave these files set to a 755 (the same as the directory). You can change the entire directory by doing sudo chmod -R 755 /var/www/nginx-default/.
If there is not an index file in the directory, however, you will still get the same error. The index file is used when you request a directory that doesn't have directory listings enabled. The most common index file is index.html. This default can be edited in your config, however, using something like:
location / {
index index.php;
If you want nginx to generate a list of files in that directory for you, simply turn on directory indexing, like so:
location / {
autoindex on;
