24
I'm trying to change the XAMPP's web root default directory /opt/lampp/htdocs to another one like /home/me/Dropbox/public_html without success.
I've edited the file /opt/lampp/etc/httpd.conf
# old line: DocumentRoot "/opt/lampp/htdocs"
DocumentRoot "/home/me/Dropbox/public_html"
#...etc...
# old line: <Directory "/opt/lampp/htdocs">
<Directory "/home/me/Dropbox/Work/public_html">
# Possible values for the Options directive are "None", "All",
# or any combination of:
#   Indexes Includes FollowSymLinks SymLinksifOwnerMatch ExecCGI MultiViews
# etc...
I've did this as said in this article: Using Ubuntu One to synchronise htdocs?
Then I've restarted Apache and I've got a permission error 403 on every page I've called with the web browser.
So I've changed folder and files permission to 755.
What file permissions should I set on web root?
The problem still remains the same, I have the 403 error on every page I try to reach with the web browser.
I have the same problem on a Mac using XAMPP.
So everythig works fine if the folder remains the original /opt/lampp/htdocs.
How can I change it correctly?
SharpC
  • 115
vitto
  • 443
9 Answers9
19
Open /opt/lampp/etc/httpd.conf change nobody and nogroup
<IfModule unixd_module>
# If you wish httpd to run as a different user or group, you must run
# httpd as root initially and it will switch.
# User/Group: The name (or #number) of the user/group to run httpd as.
# It is usually good practice to create a dedicated user and group for
# running httpd, as with most system services.
User nobody
Group nogroup
</IfModule>
to your username and your group
hellocatfood
  • 3,379
Had the same issue and here is what i did:
Run this command to stop xampp:
sudo /opt/lampp/lampp stop
Change your_folder to the folder you wanna use
 DocumentRoot "/home/username/your_folder"
 <Directory "/home/username/your_folder">
Change User & Group value from daemon to:
User nobody
Group nogroup
set chmod to your_folder with this command
sudo chmod 777 /home/username/your_folder
Save the file and start xampp with this command:
sudo /opt/lampp/lampp start
Open your browser and enter this url:
http://localhost/your_folder/
Done, hope this helps.
Exil
  • 545
Had the same problem under linux 18.3. None of the above worked exactly as described, but the following combination did:
In the file /opt/lampp/etc/httpd.conf I made the following changes:
Replace:
    User daemon
    Group daemon
    </IfModule>
by:
    User myusername
    Group myusername
    </IfModule>
and further down replace:
by
    DocumentRoot "/home/myusername/webdir"
    <Directory "/home/myusername/webdir"
Thereby, "myusername" is my linux username, and "webdir" is the directory name in my home directory where the php-files are stored.
In the terminal, stop lampp before saving the file, start again. In the browser localhost will then point to "webdir".
Michal
You can create a symbolic link
ln -s /home/username/public_html/ /opt/lampp/yoursymlink
with your username "~username" as symbolic link so you can keep the same URL location
localhost/~username for files like if your were using default Apache server and not XAMPP.
baptx
  • 527
The problem was on user group type in httpd.conf file which must be set to staff and then I don't need to change the folder permissions on the folder i'd like to use as web root.
vitto
  • 443
If you are doing this so that you can create files in htdocs folder then Just navigate to opt/lampp and then open in terminal and write
sudo chmod 777 htdocs/
Thats it!
Just solved it following the steps bellow:
  1. First install xampp by following steps
    $ sudo cd Downloads && sudo chmod a+x ./your-downloaded-xampp-file.run && sudo ./your-downloaded-xampp-file.run
  2. Change file owner of /opt/lampp directory. username should be the username of your new documentroot folder ownername
    sudo chown -hR  username:root /opt/lampp
  3. edit /opt/lampp/etc/httpd.conf
    sudo gedit /opt/lampp/etc/httpd.conf
  4. edit your document root path to mounted windows documentroot and the following lines
       User nobody
       Group nogroup
    </IfModule>
  5. restart xampp. And you will find forbidden error has gone
Braiam
  • 69,112
Nur Rony
  • 262
-1
In NTFS format you can't set folder permissions. Open /opt/lampp/etc/httpd.conf.
Edit
User computerName
Group computerName
And after that you can access the symbolic links in htdocs.
jokerdino
  • 41,732
-2
Just make an index file on your new htdocs folder.
Eliah Kagan
  • 119,640
