So I stupidly was too lazy to disable Windows 10 updates. The creator's update came and hit me, and after it was finished GRUB seems to have disappeared. The only boot device that shows up in my boot manager or BIOS is the Windows Boot Manager.
In Windows, I can still see my Linux partition listed as a healthy, primary partition. However, running test-disk from Windows lists that same partition as a Microsoft Data partition (MS Data) which definitely can't be right. I tried using test-disk to set the partition type to Linux Reserved (there's no option for just "Linux" as I've seen in some screenshots) but GRUB is still gone. I don't currently have access to a USB and can't create a live disk.
The only other partitions that show up in test-disk are an EFI system partition, a recovery partition, and my Windows partition (which is getting deleted as soon as I have Ubuntu back). I'm pretty sure both the EFI and recovery partitions are Windows related. I'm currently running a deep search in test-disk in case anything else is missing, but in the meantime is there anything that I can do to get Ubuntu back?
I'm not familiar with what this specific Windows update does; however, there are several possible things that might have happened, as explained in these questions and answers:
You may be able to fix the problem with EasyUEFI in Windows, or with bcdedit if that fails. In a worst-case scenario, you may need to completely reinstall GRUB with Boot Repair (or install another boot loader entirely).
Note that modern EFI-based computers don't boot disks per se, at least not in the same way that BIOS-based computers do. Instead, EFI booting is controlled by files on the EFI System Partition (ESP), with entries in NVRAM that point to specific files. (There can also be boot loaders stored on devices like network cards for network booting; and a standardized fallback filename is used to boot from external media and, when all else fails, from an internal hard disk.)
DO NOT use TestDisk in this situation! In all probability, it will be useless at best and could cause much worse problems if you make a mistake with it! TestDisk is useful for correcting partitioning disasters (like accidentally wiping out a partition table with fdisk, gdisk, parted, dd, etc.), but you've presented no evidence that this is the type of problem you're having.
Rod Smith
  • 45,120
  • 66
  • 108
-1
I installed a hot swap drive caddy with two drive slots, each with its own power switch. I just turn off windows 10 so it can't hijack the Ubuntu bootloader.
