19
I have a long and long-running bash script where a handful of commands need to be run as root while the majority of commands need to be run as the regular user before sudo, because it would mess up file ownership and such.
I came up with some methods, but each of them have some problems
Method 1: Using sudo inside the file
#!/bin/bash
sudo echo "I must be run by root"
touch needsToBeOwnedByUser1
echo "needs to be run by user"
sleep 1000
sudo echo "I, again, must be run by root"
This would look good, from the way the code is written. sudo is written before the few statements that actually need to be run by root, but if the time between each sudo call is too long sudo again asks for a password. Also, if the first execution of sudo fails, e.g. due to an invalid password, the rest of the script is still executed.
Method 2: using sudo to call the file and then change back to the original user when needed
#!/bin/bash
su username -c 'touch needsToBeOwnedByUser1'
su username -c 'echo "needs to be run by user"'
su username -c 'sleep 1000'
This also sucks, because I need to add su username -c in front of almost every line. Also finding the original username after sudo is possible, but cumbersome.
Is there a better way?
Edit: I only posted small, nonsensical scripts here to show what I am talking about. In the actual script I have some lines that need sudo (starting and stopping services), some lines where it does not matter if there is sudo and quite a lot of lines that really need to be run without sudo.
Dakkaron
  • 304
Regarding method 2, it's easier to use a function. For example:
#!/bin/bash
func(){
    echo "Username: $USER"
    echo "    EUID: $EUID"
export -f func
func
su "$SUDO_USER" -c 'func'
$SUDO_USER is the sudoer's username. You could also use $(logname) in its place.
Running on my machine:
$ sudo bash test.sh
[sudo] password for wja:
Username: root
    EUID: 0
Username: wja
    EUID: 1000
wjandrea
  • 14,504
By reading man sudoers, one sees:
 PASSWD and NOPASSWD
   By default, sudo requires that a user authenticate him or herself
   before running a command.  This behavior can be modified via the
   NOPASSWD tag.  Like a Runas_Spec, the NOPASSWD tag sets a default for
   the commands that follow it in the Cmnd_Spec_List.  Conversely, the
   PASSWD tag can be used to reverse things.  For example:
   ray     rushmore = NOPASSWD: /bin/kill, /bin/ls, /usr/bin/lprm
   would allow the user ray to run /bin/kill, /bin/ls, and /usr/bin/lprm
   as root on the machine rushmore without authenticating himself.
Thus, you could allow regular on host machine1 to execute command1 and command2 as root, without password authentication with:
reguser machine1 root = NOPASSWD: /usr/local/command1, /usr/local/command2
but read each of man -k sudo for details.
waltinator
  • 37,856
-2
Maybe this can help:
chmod 775 yourscript.sh
Then you can use sudo inside of the script (without password prompt) And can not use sudo for other commands inside your script.
