The problem
In a bash script, I am using the command...
sudo -u node bash
.. to switch from root to a non-sudo user, and this is failing.
The context
I am writing a provision.sh script for Vagrant, to set up a server running Ubuntu 16.04.3 with all the packages required to deliver an app with Meteor 1.6.
One required step is to install nvm as a non-root user. After nvm is installed, you need to log out and log back in again in order to activate nvm. I therefore create a non-sudo user named meteor, and want to switch to that when I download and install nvm.
Subsequently, I want to switch back to being root and log in gain immediately as meteor, in order to start using nvm to install Node.js.
You'll find a heavily commented script below. Vagrant runs this script each time I call vagrant reload --provision.
What command should I be using instead of sudo -u node bash?
echo "# whoami" && whoami && echo "^^^^ root expected"
echo "As root, create non-sudo user meteor:"
pass=$(perl -e 'print crypt($ARGV[0], "password")' $password)
useradd -m -p $pass meteor
echo "User meteor created. ls -al /home/meteor:"
ls -al /home/meteor
echo "Install curl as root:"
apt-get install -y curl
echo "Trying sudo -u meteor bash"
sudo -u meteor bash #### THIS IS THE LINE THAT FAILS ###
echo "$ whoami" && whoami && echo "^^^^^^ meteor expected"
curl -o- https://raw.githubusercontent.com/creationix/nvm/v0.33.6/install.sh | bash
echo "ls -al /home/meteor/.nvm # should be populated"
echo "ls -al /root/.nvm # should not exist"
ls -al /root/.nvm
echo "command -v nvm will fail silently until we log out and back in again"
#command -v nvm
exit
#### Because the script is still running as root, it halts here ####
echo "# whoami" && whoami && echo "^^^^ should be root"
sudo -u meteor bash
echo "$ whoami" && whoami && echo "^^^^^^ should be meteor"
echo "command -v nvm should work now"
command -v nvm
