I've looked over dozens of similar questions, nothing has jumped out as applicable. ls returns "arduino-1.8.3" {lower case} ron@ron:~$ cd (or sudo cd) /arduino-1.8.3 returns No Such File or Directory"
In the directory is uninstall.sh but it won't run from the file manager.
I realize I'm probably missing something obvious to an experienced user which I'm not.
TIA
Ron
Ron
To uninstall arduino, either...
In terminal...
sudo apt-get purge arduino arduino-core
or
If the arduino folder is in your home folder...
In terminal...
cd ~/arduino-1.8.3 # use the exact folder name here
sudo ./uninstall.sh
heynnema
  • 73,649
if i get your problem as like you want to remove arduino from your pc but cant, probably your problem, not writing down the programme name fully, so pls learn the exact name by using;
dpkg -l |grep arduino
and pls go this links as told before;
How can I uninstall software?
solfish
  • 1,591
