I've been trying to update my 15.04 machine to a more recent version, considering 15.04 is no longer supported.
The usual do-release-upgrade did not work. It showed that there is an update available (to 16.04, xenial), however, if I tried to run it, I received the following error: An upgrade from 'vivid' to 'xenial' is not supported with this tool.
After some googling, I've read that I had to upgrade 15.04 to 15.10 first and then to 16.04.
To upgrade to 15.10 I was supposed to use do-release-upgrade -d. But it did not do the trick. It said there were no upgrades available.
I have also tried solution suggested at How to install software or upgrade from an old unsupported release? but with no success. When I manually looked at http://old-releases.ubuntu.com/ubuntu/dists/ I could not even find files for Vivid nor Wily.
So how could I upgrade my machine? Doing fresh install is really not an option at this point.
Thank you in advance!
Arronical
  • 20,241
There is no longer a supported upgrade path from 15.04 to any newer release; you cannot upgrade to 15.10, because it is no longer available from Canonical, and you cannot upgrade to a newer version without that step. Your only choice is to install clean, with appropriate data preservation steps first.
Zeiss Ikon
  • 5,248
