This is my first venture into using Linux. Things have been mostly smooth, but I have run into an issue with sound: there is none.
I have checked this site, Google, and various other areas to no avail. I am by no means a novice user, but as stated above I am largely ignorant to how Linux handles driver compiles and installation. Any help, even just a point in the right direction, would be greatly appreciated!
- System:
- AMD Ryzen 1700X
- MSI X370 SLI Plus Motherboard with Realtek ALC892 chipset.
- OS: Ubuntu GNOME 17.04, Kernel: 4.11.0
Everything works so far except there is no sound. I have followed several guides that have claimed [SOLVED] on the issue but no luck for me. The most recent guide I have tried has been Realteks own, included in the Linux 3.0 Driver package.
The Realtek HD Audio device shows in BIOS and is enabled. However the hardware device does not show up once i boot into Linux. In sound settings only "Dummy Output" is shown as a virtual device. No hardware device is detected. I am assuming this is because the driver failed to install correctly in Ubuntu. The device outputs sound just fine in Windows 7 and 10.
Following their guide, I end up with a few errors in the ./config, make, and make install steps. I'll include the output here.
I am sure that the sound issue is due to this driver install process ailing, but I am not sure how to fix it.
Some of the errors I encountered:
checking for kernel version... 4.11.0-041100-generic
checking for GCC version... Kernel compiler:  Used compiler: gcc (Ubuntu 6.3.0-12ubuntu2) 6.3.0 20170406
*** NO PREDEFINED KERNEL COMPILER IS DETECTED
*** Assuming the same compiler is used with the current system compiler.
*** Please make sure that the same compiler version was used for building kernel.
checking for built-in ALSA... no
checking for existing ALSA module... yes
error: macro "__DATE__" might prevent reproducible builds [-Werror=date-time]
"Compiled on " __DATE__ " for kernel %s"
Makefile:167: recipe for target 'compile' failed
make: *** [compile] Error 2
make[1]: Entering directory '~/Downloads/Rt-Linux-HDaudio-5.18/alsa-driver-RTv5.18/alsa/acore'
mkdir -p /lib/modules/4.11.0-041100-generic/kernel/sound/acore
cp snd-hrtimer.ko snd-hwdep.ko snd-page-alloc.ko snd-pcm.ko snd-rawmidi.ko snd-timer.ko snd.ko /lib/modules/4.11.0-041100-generic/kernel/sound/acore
cp: cannot stat 'snd-hrtimer.ko': No such file or directory
cp: cannot stat 'snd-hwdep.ko': No such file or directory
cp: cannot stat 'snd-page-alloc.ko': No such file or directory
cp: cannot stat 'snd-pcm.ko': No such file or directory
cp: cannot stat 'snd-rawmidi.ko': No such file or directory
cp: cannot stat 'snd-timer.ko': No such file or directory
cp: cannot stat 'snd.ko': No such file or directory
~/Downloads/Rt-Linux-HDaudio-5.18/alsa-driver-RTv5.18/alsa/Rules.make:48: recipe for target 'modules_install' failed
make[1]: *** [modules_install] Error 1
make[1]: Leaving directory '~/Downloads/Rt-Linux-HDaudio-5.18/alsa-driver-RTv5.18/alsa/acore'
Makefile:206: recipe for target 'install-modules' failed
make: *** [install-modules] Error 1
