I am trying to set up an Emby server with libraries located on different internal hard drives. Emby requires that I give the user it creates (emby) access to folders/files when I want it to read them. To that end, I have added emby to the group adm and given ownership of the files over to emby.
However, emby still refuses to see my inside my hard drives. It can see files located on my desktop (also owned by emby) but nothing in any external hard drive.
Is there some unique property external hard drive permissions have that I am overlooking?
You need to change owner and group of the folder/HDD using next command.
sudo chown user:user -R /path/to/hdd/folder/
Replace the: user:user with your own user and group that you need it.
The option -R it will change owner/group across files, folder and sub-folders
Replace the: /path/to/hdd/folder/ with path that you want to change owner/group (Permissions)
Cornea Valentin
  • 739
As user MichaelBay explains in the discussion of this question, the solution is to mount hard drives to your computer using fstab. A great explanation on how to do that is here. The most upvoted answer explains in great detail on how to do it. The only additional thing I would like to point out is if you have a hard time figuring out the location of your external hard drive's path (the 'dev/sdb..') it is located on the top right corner of gparted.
