According to this answer, I can disable apport by editing /etc/default/apport and setting enabled=0.
I have done this:
$ cat /etc/default/apport
# set this to 0 to disable apport, or to 1 to enable it
# you can temporarily override this with
# sudo service apport start force_start=1
enabled=0
In fact, you can see I actually did this in December 2016:
$ stat /etc/default/apport
File: '/etc/default/apport'
Modify: 2016-12-22 09:43:01.688938268 -0500
Recently I noticed apport was running, so I stopped it and, then rebooted to see if it would come back again
$ sudo service apport stop
$ sudo reboot
However, on startup, it is indeed active again:
$ service apport status
● apport.service - LSB: automatic crash report generation
Loaded: loaded (/etc/init.d/apport; bad; vendor preset: enabled)
Active: active (exited) since Tue 2017-07-18 11:27:44 EST; 45min ago
Docs: man:systemd-sysv-generator(8)
Process: 1395 ExecStart=/etc/init.d/apport start (code=exited, status=0/SUCCESS)
Jul 18 11:27:44 foobar systemd[1]: Starting LSB: automatic crash report generation...
Jul 18 11:27:44 foobar systemd[1]: Started LSB: automatic crash report generation.
You can see I rebooted my machine at 11:27, so apport is being started at startup
$ sudo last reboot
reboot system boot 4.4.0-83-generic Tue Jul 18 11:27 still running
How can I permanently disable apport?
