My wifi suddenly stopped working even after reboot
sudo lshw -C network gives this
*-network
  description: Ethernet interface
  product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
  vendor: Realtek Semiconductor Co., Ltd.
  physical id: 0
  bus info: pci@0000:05:00.0
  logical name: eth0 version: 06
  serial: 24:b6:fd:27:e1:b8
  capacity: 1Gbit/s
  width: 64 bits
  clock: 33MHz
  capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
  configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl_nic/rtl8168e-2.fw latency=0 link=no multicast=yes port=MII speed=10Mbit/s
  resources: irq:30 ioport:e000(size=256) memory:f1104000-f1104fff memory:f1100000-f1103fff
*-network
   physical id: 2
   logical name: usb0
   serial: fa:dd:3b:86:b9:76
   capabilities: ethernet
   physical configuration: broadcast=yes driver=rndis_host driverversion=22-Aug-2005 firmware=RNDIS device ip=192.168.42.167 link=yes multicast=yes
My wifi device is intel centrino wireless n 1030 (rainbow peak)
i tried changing the iwlwifi.conf but could not be of any help then on the website i found a download https://www.intel.in/content/www/in/en/support/network-and-i-o/wireless-networking/000005511.html
these were the instructions given To install firmware:
Copy the files into the distribution-specific firmware directory, /lib/firmware.
If the directory does not work, consult your distribution documentation.
If you configure the kernel yourself, make sure firmware loading is enabled.
please note there are other two files than the iwlwifi-6000g2b-5.ucode file which does not require to be copied (one is license and the other is readme) and then it was up again
however a new problem was encountered wifi dropping after few hours
dmesg | grep iwl gives the follwoing
[   20.654434] iwlwifi 0000:09:00.0: loaded firmware version 18.168.6.1 op_mode iwldvm
[   21.575195] iwlwifi 0000:09:00.0: CONFIG_IWLWIFI_DEBUG disabled
[   21.575199] iwlwifi 0000:09:00.0: CONFIG_IWLWIFI_DEBUGFS enabled
[   21.575200] iwlwifi 0000:09:00.0: CONFIG_IWLWIFI_DEVICE_TRACING enabled
[   21.575203] iwlwifi 0000:09:00.0: Detected Intel(R) Centrino(R) Wireless-N 1030 BGN, REV=0xB0
[   21.575256] iwlwifi 0000:09:00.0: L1 Disabled - LTR Disabled
[   21.595943] ieee80211 phy0: Selected rate control algorithm 'iwl-agn-rs'
[   27.574648] iwlwifi 0000:09:00.0: L1 Disabled - LTR Disabled
[   27.581175] iwlwifi 0000:09:00.0: L1 Disabled - LTR Disabled
[   27.581262] iwlwifi 0000:09:00.0: Radio type=0x2-0x2-0x1
[   27.648799] iwlwifi 0000:09:00.0: L1 Disabled - LTR Disabled
[   27.655322] iwlwifi 0000:09:00.0: L1 Disabled - LTR Disabled
[   27.655409] iwlwifi 0000:09:00.0: Radio type=0x2-0x2-0x1
[ 2240.088860] iwlwifi 0000:09:00.0: L1 Disabled - LTR Disabled
[ 2240.095386] iwlwifi 0000:09:00.0: L1 Disabled - LTR Disabled
[ 2240.095475] iwlwifi 0000:09:00.0: Radio type=0x2-0x2-0x1
[ 2240.163097] iwlwifi 0000:09:00.0: L1 Disabled - LTR Disabled
[ 2240.169634] iwlwifi 0000:09:00.0: L1 Disabled - LTR Disabled
[ 2240.169729] iwlwifi 0000:09:00.0: Radio type=0x2-0x2-0x1
i aslo have refrred to the bug reporting https://bugs.launchpad.net/ubuntu/+source/linux-firmware/+bug/1420935 have tried the following Create a file named: /etc/modprobe.d/wifi_bug.conf
Add the following lines to the file: options iwlmvm power_scheme=1 options iwlwifi bt_coex_active=N swcrypto=1 11n_disable=1
Set the file's ownership the same as other files in that folder.
Reboot.
worked for a while , problem persists as of now the kernel version i am using is 4.4.0-130-generic
From this answer: Reset WiFi you can power your WiFi off and on again after a reboot. This will simulate the physical power button cycling off and on which works for your laptop.
Hardware Testing Required
https://askubuntu.com/a/1065770/623433
this is the solution that worked for me
