-1
This is the statuts of my hardisk , How can I clean the boot partion to free some space
hous
  • 225
It looks like your boot partition is also your root partition, so you need to clean up your Ubuntu installation. What really needs to happen, is your root partition needs to be larger, maybe 30-50 GBytes, but that's not the question, is it?
To clean up your root partition, the easiest way would be to install BleachBit, run it in superuser mode, and check what you want cleaned up.
Install BleachBit by running:
sudo apt install bleachbit
Here are a few other things I do from time to time keep my system clean.
Option 1: Run autoclean and autoremove to get rid of any packages you don't need any more. I type this in sometimes while installing/removing programs because it's quick and easy.
sudo apt autoclean
sudo apt autoremove
Option 2: Open up the Ubuntu Software Center, and click the Installed tab, and scroll through the list, removing any software packages you no longer need or want.
Option 3: Install Ubuntu Tweak and use it's Janitor tab to clean up unwanted data sitting around on your system. You check the left check-boxes to scan and find data, and then you check the right side to select what you want to delete. I find that Ubuntu Tweak will still get some things BleachBit doesn't, plus Ubuntu Tweak will remove old Linux Kernels and re-do grub for you. Just now, Ubuntu Tweak Janitor actually freed up more disk space (~500MBytes) on my system than BleachBit did (~270MBytes), and I ran BleachBit first.
Ubuntu Tweak is "obsolete ware", because the developer announced about a year ago (May 2016) that he would no longer be developing it. It has still worked great for me, but you may not want to use it at all, especially as time goes on. It is the only way I know to completely remove old kernels, as it seems BleachBit and autoremove don't do the trick yet when it comes to completely removing old kernels, or maybe I just don't know how it is done with those tools.
SunnyDaze
  • 1,416
