I'm trying to install the most stable, boring version of GIMP available, without adding special repositories. I'm assuming the correct way to do this is sudo apt install gimp. Unfortunately, I'm getting the following warning:
WARNING: The following packages cannot be authenticated!
libbabl-0.1-0 libsdl1.2debian libamd2.4.1 libcamd2.4.1 libccolamd2.9.1
libcholmod3.0.6 libumfpack5.7.1 libgegl-0.3-0
Should this be happening? I tried running
sudo apt-key update
sudo apt-get update
which didn't fix the issue. What should I do?
Edit: Here is the full output of sudo apt install gimp:
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
libmircommon5 linux-headers-4.4.0-78 linux-headers-4.4.0-78-generic
linux-headers-4.4.0-79 linux-headers-4.4.0-79-generic
linux-image-4.4.0-78-generic linux-image-4.4.0-79-generic
linux-image-extra-4.4.0-78-generic linux-image-extra-4.4.0-79-generic
linux-signed-image-4.4.0-78-generic linux-signed-image-4.4.0-79-generic
linux-tools-4.4.0-78 linux-tools-4.4.0-78-generic linux-tools-4.4.0-79
linux-tools-4.4.0-79-generic
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
gimp-data libamd2.4.1 libbabl-0.1-0 libcamd2.4.1 libccolamd2.9.1
libcholmod3.0.6 libgegl-0.3-0 libgimp2.0 libsdl1.2debian libumfpack5.7.1
Suggested packages:
gimp-help-en | gimp-help gimp-data-extras
The following NEW packages will be installed:
gimp gimp-data libamd2.4.1 libbabl-0.1-0 libcamd2.4.1 libccolamd2.9.1
0 upgraded, 11 newly installed, 0 to remove and 0 not upgraded.
Need to get 14.0 MB of archives.
After this operation, 79.8 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Install these packages without verification? [y/N] n
E: Some packages could not be authenticated
EDIT: I don't believe this question is a duplicate of any of the questions suggested by reviewers:
- Why am I getting authentication errors for packages from an Ubuntu repository? None of the answers are the one that worked for me.
- W: GPG error and WARNING: The following packages cannot be authenticated! Does not have the answer that worked for me.
- Trouble downloading packages list due to a "Hash sum mismatch" error This is not the error I got initially.
