When I try to run Chromium(chromium-browser), it displays only the title bar and a border. Here's the error log:
Gkr-Message: secret service operation failed: The name org.freedesktop.secrets was not provided by any .service files
Received signal 4 <unknown> 000076283f76
#0 0x000076ed7d12 base::debug::StackTrace::StackTrace()
#1 0x000076ed7952 base::debug::StackTrace::StackTrace()
#2 0x000076ed7ffc <unknown>
#3 0x0000722cd270 <unknown>
[end of stack trace]
Calling _exit(1). Core file will not be generated.
[3728:3728:0714/230011.042444:ERROR:sandbox_linux.cc(343)] InitializeSandbox() called with multiple threads in process gpu-process.
[3651:3681:0714/230011.074254:ERROR:browser_gpu_channel_host_factory.cc(103)] Failed to launch GPU process.
[3651:3681:0714/230011.075020:ERROR:browser_gpu_channel_host_factory.cc(103)] Failed to launch GPU process.
[3651:3681:0714/230011.075433:ERROR:browser_gpu_channel_host_factory.cc(103)] Failed to launch GPU process.
[3651:3681:0714/230011.075699:ERROR:browser_gpu_channel_host_factory.cc(103)] Failed to launch GPU process.
[3651:3681:0714/230011.075936:ERROR:browser_gpu_channel_host_factory.cc(103)]     Failed to launch GPU process.
Received signal 4 <unknown> 00007622ff76
#0 0x000076e83d12 base::debug::StackTrace::StackTrace()
#1 0x000076e83952 base::debug::StackTrace::StackTrace()
#2 0x000076e83ffc <unknown>
#3 0x000072279270 <unknown>
How can I get this to work?
NOTE: I've had a similar problem with Xubuntu as well, but it works fine on Raspbian.
From looking here, I think that it might be problem from a new update, becuase updating chromium caused it to happen in the first place.
If this is true, Could you please tell me how to downgrade (Opposite of upgrade) to a version below 59?
Zanna
  • 72,312
After thinking about it being a version problem, I decided to look around and found this website: http://ports.ubuntu.com/pool/universe/c/chromium-browser/, the official website for the chromium found in APT repositories.
So I looked around, tried out a few versions, and finally, managed to get chromium working by installing
chromium-codecs-ffmpeg_57.0.2987.98-0ubuntu1.1348_armhf.deb
chromium-browser_57.0.2987.98-0ubuntu1.1348_all.deb
chromium-browser-l10n_57.0.2987.98-0ubuntu1.1348_all.deb
In that order. See How do I install a .deb file via the command line? if unsure; you can, for example, cd to the download directory and run
sudo apt-get install ./<name of package>.deb
Zanna
  • 72,312
I had the same problem trying to get Chromium to work on Ubuntu Mate. It wouldn't start. I took my time reading through forums trying to find out what's wrong. 15 minutes into it, it suddenly opened up on my raspberry pi's screen by itself (I guess the process was still running). After that it worked normally. I'm still not sure what it was doing there for 15 minutes
