I have dual boot ubuntu 17.04 along with Win 10.
lsblk command gave me this:
  sda      8:0    0 465.8G  0 disk
    ├─sda1   8:1    0  89.2G  0 part
    ├─sda2   8:2    0 154.1G  0 part
    ├─sda3   8:3    0 202.4G  0 part
    ├─sda4   8:4    0     1K  0 part
    └─sda5   8:5    0    20G  0 part /
sda1,sda2,sda3 become read only, and I cant write anything to it. I've tried How to fix "The destination is read-only" error on HDD pratishthan But none of the answers worked for me. Please Help.
Open the terminal and write the command
sudo fdisk -l
It will show your file system
identify the partition you want permission for read and write
then type the command and give the partition name like this
sudo ntfsfix /dev/sda3
One of the possible fixes is the following: On Windows, you have to turn off the fast startup option (here's how to do it: https://www.asus.com/support/FAQ/1045548). Then shut down your system (shutdown, not restart!). You should be then able to edit the Windows partition from Ubuntu.
NB: the fast startup option is reenabled by Windows after some updates. You will then have to do it again.
Likid
