15
I received a ZIP file from a Japanese customer.
When I try to unzip it the file and folders names are messed up:
$ unzip ~/Downloads/【新入荷ECM】資料.zip
 inflating: БyРVУ№Й╫ECMБzОСЧ┐/123_ГЖБ[ГXГPБ[ГX.xlsx
What is the problem, and how to avoid it?
muru
  • 207,228
Nicolas Raoul
  • 11,921
The problem is that most ZIPs circulating in Japan have their content encoded as Shift JIS, which is not shown correctly by default on Ubuntu.
The solution is to use the -O shift-jis option in your command:
$ unzip -O shift-jis ~/Downloads/【新入荷ECM】資料.zip
 inflating: 【新入荷ECM】資料/123_ユースケース.xlsx
This way, the expanded files are perfectly readable in Ubuntu.
Nicolas Raoul
  • 11,921
Simple answer for this
$ sudo apt install unar
$ unar ~/Downloads/【新入荷ECM】資料.zip
unar can automatically recognize which encoding is used. It does only extract and not for compressing.
Then use 'convmv' to encode text after extract.
$ convmv -f shift_jis -t utf8 БyРVУ№Й╫ECMБzОСЧ┐/123_ГЖБ[ГXГPБ[ГX.xlsx --notest
Vice versa, if you'd like to create file(s) from utf8 into shift_jis text for windows.
$ convmv -f utf8 -t shift_jis <filename> --notest
Alternative answers, use of Ubuntu Japanese team built automatic encoding 'unzip' but you have to add repository.
Nicolas Raoul
  • 11,921
