Firstly, I've looked at the various other questions and answers on this topic and they've not fixed my problem, so I've not just dashed in without a long stint on Google and here. Also, there's no separate boot partition and there's plenty of space available.
I'm on 16.04 and I think what happened was that my laptop got rebooted or crashed while running an update. Certainly it was unexpectedly off when I came back to it and now I can not install anything with apt-get. In my pursuit of a solution the only major change from where it was at that point is that I tried forcing the removal of linux-generic as suggested somewhere but although that succeeded in removing the package it would not reinstall.
Currently I've been able to fall back to kernel 4.8.0-54-generic which is working reasonably well (I'm using the laptop now).
I'll start with dpkg --audit:
The following packages have been unpacked but not yet configured.
They must be configured using dpkg --configure or the configure
menu option in dselect for them to work:
 linux-generic-hwe-16.04 Complete Generic Linux kernel and headers
 linux-image-extra-4.8.0-56-generic Linux kernel extra modules for version 4.8.
 linux-image-extra-4.8.0-58-generic Linux kernel extra modules for version 4.8.
 linux-image-generic-hwe-16.04 Generic Linux kernel image
The following packages are only half configured, probably due to problems
configuring them the first time. The configuration should be retried using
dpkg --configure <package> or the configure menu option in dselect:
 linux-image-4.8.0-53-generic Linux kernel image for version 4.8.0 on 64 bit x8
 linux-image-4.8.0-56-generic Linux kernel image for version 4.8.0 on 64 bit x8
 linux-image-4.8.0-58-generic Linux kernel image for version 4.8.0 on 64 bit x8
The following packages are only half installed, due to problems during
installation. The installation can probably be completed by retrying it;
the packages can be removed using dselect or dpkg --remove:
 linux-image-extra-4.4.0-83-generic Linux kernel extra modules for version 4.4.
 linux-image-extra-4.8.0-53-generic Linux kernel extra modules for version 4.8.
Running for i in /boot/vmlinuz* ; do dpkg -S $i | egrep -v $(uname -r); done |cut -d- -f3-4 outputs:
4.4.0-53
4.8.0-53
4.8.0-56
4.8.0-58
dpkg basically won't do anything except some deletions. So dpkg --configure -a produces:
Setting up linux-image-4.8.0-53-generic (4.8.0-53.56~16.04.1) ...
Running depmod.
update-initramfs: deferring update (hook will be called later)
Not updating initrd symbolic links since we are being updated/reinstalled
(4.8.0-53.56~16.04.1 was configured last, according to dpkg)
Not updating image symbolic links since we are being updated/reinstalled
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.8.0-53-generic /boot/vmlinuz-4.8.0-53-generic
run-parts: executing /etc/kernel/postinst.d/dkms 4.8.0-53-generic /boot/vmlinuz-4.8.0-53-generic
Error! Your kernel headers for kernel 4.8.0-53-generic cannot be found.
Please install the linux-headers-4.8.0-53-generic package,
or use the --kernelsourcedir option to tell DKMS where it's located
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 4.8.0-53-generic /boot/vmlinuz-4.8.0-53-generic
update-initramfs: Generating /boot/initrd.img-4.8.0-53-generic
cp: cannot stat '/etc/fonts/conf.d/60-latin.conf': No such file or directory
E: /usr/share/initramfs-tools/hooks/plymouth failed with return 1.
update-initramfs: failed for /boot/initrd.img-4.8.0-53-generic with 1.
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-4.8.0-53-generic.postinst line 1052.
dpkg: error processing package linux-image-4.8.0-53-generic (--configure):
 subprocess installed post-installation script returned error exit status 2
Setting up linux-image-4.8.0-58-generic (4.8.0-58.63~16.04.1) ...
Running depmod.
The link /initrd.img is a dangling linkto /boot/initrd.img-4.8.0-56-generic
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.8.0-58-generic /boot/vmlinuz-4.8.0-58-generic
run-parts: executing /etc/kernel/postinst.d/dkms 4.8.0-58-generic /boot/vmlinuz-4.8.0-58-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 4.8.0-58-generic /boot/vmlinuz-4.8.0-58-generic
update-initramfs: Generating /boot/initrd.img-4.8.0-58-generic
W: Possible missing firmware /lib/firmware/i915/kbl_dmc_ver1_01.bin for module i915
update-initramfs: failed for /boot/initrd.img-4.8.0-58-generic with 1.
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-4.8.0-58-generic.postinst line 1052.
dpkg: error processing package linux-image-4.8.0-58-generic (--configure):
Setting up linux-image-4.8.0-56-generic (4.8.0-56.61~16.04.1) ...
Running depmod.
The link /initrd.img is a dangling linkto /boot/initrd.img-4.8.0-58-generic
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.8.0-56-generic /boot/vmlinuz-4.8.0-56-generic
run-parts: executing /etc/kernel/postinst.d/dkms 4.8.0-56-generic /boot/vmlinuz-4.8.0-56-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 4.8.0-56-generic /boot/vmlinuz-4.8.0-56-generic
update-initramfs: Generating /boot/initrd.img-4.8.0-56-generic
update-initramfs: failed for /boot/initrd.img-4.8.0-56-generic with 1.
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-4.8.0-56-generic.postinst line 1052.
dpkg: error processing package linux-image-4.8.0-56-generic (--configure):
dpkg: dependency problems prevent configuration of linux-image-generic-hwe-16.04:
 linux-image-generic-hwe-16.04 depends on linux-image-4.8.0-58-generic; however:
  Package linux-image-4.8.0-58-generic is not configured yet.
dpkg: error processing package linux-image-generic-hwe-16.04 (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-image-extra-4.8.0-58-generic:
 linux-image-extra-4.8.0-58-generic depends on linux-image-4.8.0-58-generic; however:
dpkg: error processing package linux-image-extra-4.8.0-58-generic (--configure):
dpkg: dependency problems prevent configuration of linux-image-extra-4.8.0-56-generic:
 linux-image-extra-4.8.0-56-generic depends on linux-image-4.8.0-56-generic; however:
  Package linux-image-4.8.0-56-generic is not configured yet.
dpkg: error processing package linux-image-extra-4.8.0-56-generic (--configure):
dpkg: dependency problems prevent configuration of linux-generic-hwe-16.04:
 linux-generic-hwe-16.04 depends on linux-image-generic-hwe-16.04 (= 4.8.0.58.29); however:
  Package linux-image-generic-hwe-16.04 is not configured yet.
dpkg: error processing package linux-generic-hwe-16.04 (--configure):
Notice that it complains about missing header files for a different kernel from the one actually running (-53 instead of -54, both of which are quite far behind the highest kernel I had installed before this mess erupted).
apt-get -f install gives:
 Reading package lists... Done
 Building dependency tree
 Correcting dependencies... Done
 The following packages were automatically installed and are no longer required:
   linux-headers-4.4.0-83 linux-headers-4.4.0-83-generic linux-image-4.4.0-83-generic linux-image-extra-4.4.0-83-generic
 Use 'sudo apt autoremove' to remove them.
 The following additional packages will be installed:
   libcogl-common libcogl-pango20 linux-image-4.4.0-83-generic
 Suggested packages:
   fdutils linux-doc-4.4.0 | linux-source-4.4.0 linux-tools
 The following packages will be REMOVED
 The following NEW packages will be installed
 0 to upgrade, 3 to newly install, 1 to remove and 78 not to upgrade.
 9 not fully installed or removed.
 Need to get 0 B/58.0 MB of archives.
 After this operation, 94.3 MB disk space will be freed.
 Do you want to continue? [Y/n] y
 (Reading database ... 389562 files and directories currently installed.)
 Removing linux-image-extra-4.8.0-53-generic (4.8.0-53.56~16.04.1) ...
 dpkg: error processing package linux-image-extra-4.8.0-53-generic (--remove):
  subprocess installed post-removal script returned error exit status 1
Finally, apt-get upgrade gives:
 You might want to run ‘apt-get -f install’ to correct these.
 The following packages have unmet dependencies.
  libclutter-1.0-0 : Depends: libcogl-pango20 (>= 1.17.4) but it is not installed
                     Recommends: libclutter-1.0-common but it is not installed
  linux-image-extra-4.4.0-83-generic : Depends: linux-image-4.4.0-83-generic but it is not installed
 E: Unmet dependencies. Try using -f.
And that's where I am. There doesn't seem to be a lot wrong - just a few kernel packages screwed up but I'm having a bad time trying to resolve it. I'd rather not have to reinstall as there are databases on this machine which would be lost and I don't have space to back up at the moment. They're not critical but it would take a day or two rebuild them and at the moment the machine is actually working well, except for the fact that it can't be updated.
What do I try next?
BobLong
  • 81
I actually faced problem that same with you. And I think, I just fix it. See screenshot here
First, download and install linux-headers-4.8.0-53_4.8.0-53.56~16.04.1_all.deb.
Then, download and install linux-headers-4.8.0-53-generic_4.8.0-53.56~16.04.1_amd64.deb.
Try apt update then apt upgrade.
UPDATE
If you find error like E: Sub-process /usr/bin/dpkg returned an error code (1), just follow these step.
  1. Run dpkg --remove --force-remove-reinstreq linux-image-extra-4.8.0-58-generic
  2. Then run apt install linux-image-extra-4.8.0-58-generic
