I have a pretty standard "but it is not going to be installed" error on Ubuntu 16.04.01. For example:
sudo apt-get install libpq-dev
Reading package lists... Done
Building dependency tree
libpq-dev : Depends: krb5-multidev but it is not going to be installed
So let's go ahead and install that ourselves:
sudo apt-get install libpq-dev krb5-multidev
krb5-multidev : Depends: libkrb5-3 (= 1.13.2+dfsg-5) but 1.13.2+dfsg-5ubuntu2 is to be installed
Depends: libk5crypto3 (= 1.13.2+dfsg-5) but 1.13.2+dfsg-5ubuntu2 is to be installed
Depends: libgssapi-krb5-2 (= 1.13.2+dfsg-5) but 1.13.2+dfsg-5ubuntu2 is to be installed
Let's continue:
sudo apt-get install libpq-dev krb5-multidev libkrb5-3 libk5crypto3 libgssapi-krb5-2
libk5crypto3 is already the newest version (1.13.2+dfsg-5ubuntu2).
libk5crypto3 set to manually installed.
libgssapi-krb5-2 is already the newest version (1.13.2+dfsg-5ubuntu2).
libgssapi-krb5-2 set to manually installed.
libkrb5-3 is already the newest version (1.13.2+dfsg-5ubuntu2).
libkrb5-3 set to manually installed.
and you can continue time and again until you get bored and stop.
/etc/apt/sources.list:
deb http://archive.ubuntu.com/ubuntu xenial main universe restricted multiverse
deb-src http://archive.ubuntu.com/ubuntu trusty main restricted #Added by software-properties
And I have tried to update my sources.list with software-properties and literally tried everything here to resolve it to no luck.
