I have tried installing capt drivers(v2.71) from official canon page. Somehow it doesn't work. Anyone found any way/solutions (either official or unofficial) to make this printer work in Zesty?
so there are 4 steps: 1) install drivers 2) Register the printer (PPD) with the print spooler 3) Register the printer in the ccpd daemon setup file. 4) Start ccpd daemon
I wonder if you did all those; would you like detailed instructions? and what does dpkg -l cndrvcups* give in a terminal please; if you can copy and paste back what you get in the terminal please
1) if we assume the drivers got installed ... then ..if you copy this next command and paste into a terminal: open the terminal with three keys control, alt and t held down ... and to paste, right-click at the text prompt and look for PASTE in the menu that appears .....
2)Register the printer sudo /usr/sbin/lpadmin -p LBP2900 -P /usr/share/cups/model/CNCUPSLBP2900CAPTK.ppd -v ccp://localhost:59787 -E
3) Register the printer in the ccpd daemon setup file .. this assumes you have only one printer; the LBP2900 connected by usb cable ..sudo /usr/sbin/ccpdadmin -p LBP2900 -o /dev/usb/lp0
4) Start ccpd daemon sudo /etc/init.d/ccpd start
...... you should now be able to print ........
- 1,132
