I am a beginner Linux user and I have a MacBook 3,1 made in 2007 running Lubuntu 16.04 64bit with Network Controller: Broadcom Limited BCM4321 802.11a/b/g/n [14e4:4328] (rev 03), Subsystem: Apple Inc. Airport Extreme [106b:0088] Kernel driver in use: b43-pci-bridge.
The wifi connection is very slow and disconnects often. Since the wifi was working under Mac OSX and Windows on the same computer/router setup, I suspect the solution is to uninstall the wifi driver and install a new one. My question is: which driver do I choose and how do I uninstall the old one and install the new one?
I followed the top-rated response of this post but the problem persists: Installing Broadcom Wireless Drivers
Thank you for reading! -Chris
cebroski
  • 23
I also have a MacBook 3,1 running Kubuntu 16.04.3 64 bit with the Broadcom Limited BCM4321 802.11a/b/g/n [14e4:4328] (rev 03).
I am using the b43 driver. It does work, but can be a pain to get set up.
How to get it working:
  1. Purge the proprietary driver.
    sudo apt-get remove --purge bcmwl-kernel-source
  2. Blacklist the drivers you don't want by making sure the following lines are in /etc/modprobe.d/blacklist.conf
    blacklist bcm43xx
    blacklist wl
  3. Reboot
  4. Install the b43 firmware
    sudo apt-get install b43-fwcutter firmware-b43-installer
  5. That should get it working. If not, you may need to reboot again.
sudo iwconfig wlan0 power off
This solves the problem temporarily only.
To make it permanent run command as follows:
  1. cd /etc/pm/power.d
  2. sudo gedit wifi_pwr_off This will open an empty file, copy the code below into it:
    #!/bin/sh /sbin/iwconfig wlan0 power off Save the file, remember to
sudo chmod +x wifi_pwr_off and restart. Please note that instead of wlan0 it can be wlan1 or so for you depending on the situation
[Link Here!][1]
Jose
