I am attempting to install Ubuntu 17.04 on my Dell XPS 15. I have disabled secure boot and hibernation mode in Windows. When I run the Ubuntu installer from a USB drive, it skips asking me what "installation type" I would prefer, and brings me right to the manual partitioning option. The problem is that nothing shows up, and clicking on the "+" and "change" buttons causes the installer to freeze: Manual Partitioning. According to GParted, Ubuntu is not recognizing my computer's SSD, merely the USB drive that I am using to boot it: GParted in "Try Ubuntu" mode. Is there a fixable bug that could be causing Ubuntu to fail to recognize the SSD?
Asked
Active
Viewed 3.6k times
Make sure to have a backup of your important Windows files!
You've got a single SSD set up in RAID mode, and the Ubuntu installer won't recognize your SSD until you switch your disk setting in the BIOS from RAID to AHCI.
Making that switch comes with some problems though, as Windows will no longer boot. Looking at this article https://samnicholls.net/2016/01/14/how-to-switch-sata-raid-to-ahci-windows-10-xps-13/ will show you how to make the change without having to reinstall Windows.
Boot to Windows with your current SATA controller configuration
Open Device Manager
Expand Storage Controllers and identify the Intel SATA RAID Controller
View properties of the identified controller
On the Driver tab, click the Update driver… button
Browse my computer…, Let me pick…
Uncheck Show compatible hardware
Select Microsoft as manufacturer
Select Microsoft Storage Spaces Controller as model
Accept that Windows cannot confirm that this driver is compatible
Save changes, reboot to BIOS and change RAID SATA Controller to AHCI
Save changes and reboot normally, hopefully to Windows
Now you should be able to install Ubuntu in a dual-boot configuration.
