I am attempting to install Ubuntu 17.04 on a Dell XPS 15 via bootable USB drive. I progress through the first few slides in the installation process just fine, but when it comes time to allocate space on the SSD, Ubuntu skips asking me what "installation type" I would prefer, and instead proceeds directly to the "something else" option that involves manually partitioning the drive. When I quit the installation process, Ubuntu strangely goes to a login screen, where it accepts any username I type in but determines any password to be incorrect. Furthermore, my SSD has four empty partitions of 1.12 GB, 11.94 GB, 450 MB, and 500 MB apiece that I believe were created during separate installation attempts. I am really at a loss, as I have never experienced an installation process like this before. Is there a fixable bug that I am not aware of that could be causing this?
An inability to do anything but a manual partitioning ("Something Else") installation is a common complaint when installing a dual-boot with Windows 8 or later. I'm not sure offhand if this is an issue related to EFI/UEFI-mode installation per se or if it's related to the notorious Windows Fast Startup and Hibernate features. These related features turn an ordinary shutdown operation into a suspend-to-disk operation, which leaves filesystems in an inconsistent state that's unsafe for sharing with other OSes. The Ubuntu installer might be detecting this and therefore refusing to provide options to resize the Windows partitions, thus closing off the usual "install alongside" type options.
Thus, one thing you might try is to disable both Fast Startup and Hibernate, as described in the links in the previous paragraph. Note that this is a critical part of a dual-boot installation with Windows 8 or later. Even aside from the installation issues, these features make it unsafe to share data between the two OSes. On EFI-based computers, even the EFI System Partition (ESP; where boot loaders are stored) is likely to be affected, which can produce all sorts of weird boot problems.
If disabling Fast Startup and Hibernate doesn't help, then the only solution is to use the "Something Else" installation option, as described here. Given your description, I recommend using Ubuntu in its "try before installing" mode to launch GParted on the disk to remove any partitions that might be left over from previous installation attempts first. You could optionally create partitions for Ubuntu in GParted at this time, too. Be 100% sure that any partitions you delete really are left over from previous Ubuntu installation attempts, though. Modern Windows installations often have several partitions, most or all of which are important to Windows in one way or another, so you should not delete them! Check the filesystem type in GParted. Ubuntu partitions are likely to use ext4fs or Linux swap. Windows partitions are likely to use FAT, NTFS, or have an unidentified filesystem. If you have any doubts, post a question, showing a GParted screen shot or the output of both sudo parted -l and sudo blkid.
- 45,120
- 7
- 66
- 108
